New member, NJ; First Corvair, '65
glecharles
Post by glecharles »
This week, I'm buying a 1965 Monza 110 sedan w/Powerglide automatic; one owner and only 37k miles. It sat in a garage in NJ for ~30 years, ; needs some TLC but has minimal rust, engine runs well, seems to be all original everything. Even has the original title, owners manual, and hubcaps!
I've joined both CORSA and NJACE, and been poking around this forum for insights, but wondering if there's a good beginners resource for a new owner?
I'm getting the mechanicals checked out first thing and definitely know all of the seals, weatherstripping, and tires need to be replaced ASAP, but not sure the ideal order of things beyond that.
Looking forward to learning from and engaging with this community!
Sent from my moto g(7) using Corvair Forum mobile app
You do not have the required permissions to view the files attached to this post.
1965 Corvair Monza 110, Sport Sedan w/ Powerglide | New Jersey
Re: New member, NJ; First Corvair, '65
Not bad for N.J. weather. Now that you are in the Corvair world a 4 door "Sport Sedan" is often called a "Moredoor". I have one that I didn't really want as I had another Corvair, but it was a solid car with factory A/C and the price was right. I've really come to like the car. It gets more attention at cars and coffee than my convertible!!!
I'm surprised nobody replied yet. As is often said here - advice depends on your abilities. What can you do, vs. hiring someone to do it.
Anyway ---- I've had a number of old cars that I buy in sad shape and bring them back. I do most of my work, otherwise it would be too expensive. The Corvair, unlike a Camaro, takes about the same money to restore, but sells for a LOT less.
After 30 years the brake master and wheel cylinders are probably corroded - you'll need new (don't bother to rebuild cylinders that are corroded).
The fuel tank is probably full of rust and crude. If so it's cheaper to put a new one in vs. trying to clean and fix an old fuel tank. And while the tank is out replace the brake line above it (can't be accesssed with the fuel tank in the car). NEVER RUN AN ENGINE ON OLD GASOLINE as it can cause the valves to seize in the guides!!! Been reported numerous times.
Change the oil, filter, and transmission fluids. I would drop the oil pan and scrap off the old crude or the new oil will get dirty FAST.
The carburetors may need to be dismantled and cleaned. After that get the engine running and you can figure out what other issues need attention. The old pushrod "O" rings didn't last long and leak oil. The new Viton "O" rings stand up well.
Don't get too many things going at once or you may get overwhelmed and loose interest.
Other's will have more to say.
Don't tear the engine apart until you figure out if it runs and do a compression check.
"NEVER RUN AN ENGINE ON OLD GASOLINE as it can cause the valves to seize in the guides!!! Been reported numerous times."
Where? I've never heard of that. 30 year old fuel is long past any ability to run.
I posted this for another new owner...
:welcome2: :wave: :wave: :clap: Welcome to the Corvair Forum!
:zzzz: A good dusting, some fresh fluids, a new battery, and new tires may be all she needs after the long sleep!
:idea: Removing your car from storage/Reviving a Dead Corvair
:link: viewtopic.php?f=225&t=5030
Corvair Forum :link: http://www.corvairforum.com/forum/viewt ... 225&t=6007
:dontknow: I would like to encourage you to expand on your initial post and tell us more about yourself, your Corvair interests, and your goals for your Corvair. Helping us to know more about you will help us to write comments to you that are tailored to your needs and experience. Detailed pictures of your Corvair — including the engine compartment — would possibly be useful. Knowing your location may also suggest possibilities in supporting your Corvair interests.
:welcome: :welcome2:
Bruins_Fan
Post by Bruins_Fan »
Welcome to CF!
doug6423
Post by doug6423 »
Always good to have another ‘65 owner Image
65 Monza
Cincinnati, OH
glecharles
Took delivery today, straight to my mechanic to look it over and see what's what. I haven't worked on any car in nearly 30 years but am looking forward to getting my hands dirty with this one.
Anyone familiar with registering an old car in NJ? I'm not looking for the historic angle, I'm planning to drive this casually, but not sure how a 55-year-old car passes inspection, etc.
Vehicles Exempt From Inspection
Exempted Vehicles
Certain vehicles are exempt from inspections, but they do vary, so be sure to check what is required for yours.
The following vehicles are exempt from inspection requirements (N.J.A.C. 13:20-7.2):
  • Gasoline powered vehicles registered passenger, model year 1995 & older with a GVWR 8,500 pounds or less.
  • Gasoline powered vehicles registered passenger, model year 2007 & older with a GVWR 8,501 to 14,000 pounds.
  • Gasoline powered vehicles registered passenger, model year 2013 & older with a GVWR 14,001 pounds or more.
  • Historic motor vehicles
  • Approved Collector Vehicles which are less than 25 years old
  • 100% Electric vehicles
  • Motorcycles
  • Motorized bicycles
  • Farm tractors and traction equipment
  • Farm machinery and implements
  • Fire trucks having a GVWR of more than 8,500 pounds
  • In-transit construction equipment
  • All Diesel-fueled motor vehicles with a gross vehicle weight rating (GVWR) 8,501 pounds to 17,999 that are plated commercial. The owner or lessee is required to inspected these vehicles.
  • All diesel powered vehicles with a gross vehicle weight rating (GVWR) 8,501 to 17,999 that are plated passenger, not for profit, governmental, commuter van, farmer or farm truck except buses
  • All diesel powered vehicles model year 1996 and older that are plated passenger, not for profit, governmental, commuter van, farmer or farm truck except buses
  • Omnibuses which are subject to inspection by the Commission‘s Commercial Bus Inspection and Investigation Unit
  • School buses which are subject to inspection by the Commission‘s School Bus Inspection Unit
  • Tactical military vehicles operated on Federal installations within this State
Historic vehicles
General inspections are not required for historic or collector vehicles. To be classified as a "historic vehicle" it must be:
  • At least 25 years old
  • Must not be modified from original manufacturer specification
  • Specially registered and display QQ plates
Collector vehicles
To be classified as a "collector vehicle" make sure that the vehicle:
  • Is not registered as a "historic vehicle" or a "street rod"
  • Is not driven more than 3,000 miles per year
  • Is insured as a limited use "collector vehicle"
  • Is not a vehicle with an elevated chassis height subject to an inspection in accordance with NJAC 13:20-37
To qualify for an exemption:
  • A vehicle must first be prequalified as a collector vehicle. Click here to see if your vehicle qualifies as a collector vehicle.
  • Visit an MVC Agency to purchase a voucher for a special decal to mark the vehicle exempt from safety and emission inspection; fee is $25 for an initial voucher and $25 to renew. You must provide the approval letter from the MVC I/M Support to the agency when initially applying collector vehicle status. The approval letter is not required for renewal.
  • Take the collector vehicle to a State Inspection Station where the inspector will verify the odometer reading
:link: https://www.state.nj.us/mvc/inspection/exemptinsp.htm
Vehicle Registration
:link: https://www.state.nj.us/mvc/vehicles/reginitial.htm
joelsplace wrote:
Mon Oct 19, 2020 3:44 pm
Gee Joel you need to go search on the CCF. Over the years folks have reported this issue. Even with fuel stabilizers gasoline the "reliable" limit on gasoline in about six months depending on storage. Plenty of information out there if you go look.
glecharles
Thanks for the welcome and helpful links! Apparently a '65 is exempt from inspection which was a nice surprise.
Initial diagnosis shows the car's in pretty solid shape, no surprises. Original tires and wheels need to be replaced, obviously, and a full tune-up, but everything else appears to be solid; minimal rust, no leaks. The interim owner had already replaced a few things (carbs, fuel tank, fuel pump, master cylinder, muffler), so there might not be much more critical work to do.
For wheels, we're looking at Pacer 144S Silver Rallyes (15") and Cooper CS5s.
Assuming no mechanical issues pop up in the short term, I'd like to restore the interior, replace all of the weatherstripping, and get a new paint job.
I did a search for "valves seize" and got 4 hits that were 8-12 years old from 2 people. I don't buy it. I have had valves stick but only on fresh gas. Gas had nothing to do with it.
Exemptions
Vehicles more than 35 years old are exempt from the annual safety inspection.
Old cars must be inherently safe. New cars MUST be inspected, however.
I guess exempting old cars from safety inspections must make sense to some bureaucrat somewhere. :clap: :dontknow: :not worthy:
Since all Corvairs are over 50 years old... NO INSPECTION IN OUR STATE!
The following states require a periodic inspection by a licensed inspection station: Delaware, Hawaii, Illinois, Louisiana, Maine, Massachusetts, Mississippi, Missouri, New Hampshire, New Jersey, New York, North Carolina, Pennsylvania, Rhode Island, Texas, Utah, Vermont, Virginia, and West Virginia, plus Washington, DC
All together, there are seven total states that have no required vehicle inspections: Alaska, Arkansas, Iowa, Minnesota, Montana, South Carolina, and South Dakota. Michigan and Mississippi also generally don't require inspections, except for in some extremely specific scenarios.
Car Inspection Requirements By State: A Compendium
:link: https://www.partsgeek.com/mmparts/car_i ... ndium.html
glecharles
New shoes finally came in! Next up, tuning the carbs and seeing what condition the engine really is in.
1966 Monza Sedan Wheels and Tires.pdf
I bought this 1966 Monza Sedan with 110 hp engine, factory A/C and Powerglide transmission from a Southern California BMW dealership in September (the seller was the General Manager of the BMW dealership). I switched wheels to a set of Foose Knuckle 17" x 7" wheels fitted with Goodyear Eagle Exhilarate 215/45ZR17 Ultra High Performance All-Season Tires. The original chrome wheels and Federal SS-657 205/60R14 All Season tires were almost new, but I wanted 17" aluminum rims and the Goodyear tires, so I will likely sell the chrome wheels and tires that the car came with.
The Monza sedan was originally a California car (built at the Van Nuys, CA plant) and had 3 previous owners (all in Southern California).
Left-click image to enlarge for better viewing.
I bought this 1966 Corsa convertible from a Florida seller back in 2012 when I first joined the Corvair Forum....
Before I bought my California Monza Sedan, I tried to bid on the 1966 Monza Sedan below at a North Carolina auction, but the bidding rapidly shot up to $19,500 and I dropped out. With the auction fees the final selling price on this 140 hp sedan with factory A/C was over $20,000!
So welcome to the "More Door" Corvair group! Please keep us posted on your progress.
glecharles
Both of your cars look amazing. I hope mine will eventually look half as good!
Sent from my SM-T290 using Corvair Forum mobile app
Return to “Introductions”
