No. [emoji2]
65 Corsa by barrist
Re: 65 Corsa by barrist
65 Monza
Cincinnati, OH
Cincinnati, OH
- GasDaddy140
Hell No! This ain't Russia!
Alan Duquette
Rohnert Park, CA
2015 Nissan Juke S
Rohnert Park, CA
2015 Nissan Juke S
Here are some options. I think I prefer the lighting system at the bottom, although the price is higher.barrist wrote: » Wed Apr 29, 2020 2:07 pm
Now, I need some "Expert Advice"
Thinking of the Amber Hi-Beam Lights,,,,,,,,,,, Yes or No ?
Thank You,
Bill
eBay https://www.ebay.com/itm/5-3-4-AMBER-GL ... 1793947755All the rage in the early 1970's now there back. Here are 2 new High End amber/yellow headlights for your classic 4 headlight car. These can be used in any quad headlight car. These are NOT Halogen and wont overload your cars electrical system.
These plug directly into your cars wiring come with a pre installed wiring adapter !! These lights have been used on very high end restorations. Thanks for looking! Included the correct Pre Installed factory correct wire adapter set!
ALTERNATE???
LQQDP 4pcs 5.75" Inch Round Black Housing Clear Lens LED Halo Angel Eye Projector Headlights Assembly H4/9003/HB2 Conversion Kit Amber Turn Signal/Parking White High/Low Beam DRL Daytime Running Light
Price: $188.00 & FREE Shipping
https://www.amazon.com/LQQDP-Projector- ... 6e7b0f409c
OR...
Octane Lighting 5-3/4 Crystal Clear Metal Glass Headlight Led 4000Lm H4 Light Bulb Headlamp Set
by Octane Lighting
These fit perfect into my 69 mustang. I plan on getting another pair for the chevelle later on. They plug right in. Would recommend.
Very bright and easy to install.
https://www.amazon.com/Octane-Lighting- ... 6e7b0f409cProduct description
THESE ARE 5.75" CRYSTAL CLEAR GLASS FACED / METAL BACKED HEADLIGHT - SET OF 4 Includes Octane Lighting H4 (9003 / HB2) 40w 6000k 4000 Lumen LED High Intensity Discharge Hi/Low Beam Headlight Light Bulbs with Canbus Error Canceller Plugs! SET OF 4 - 5-3/4" CRYSTAL H4 LED HEADLIGHT KIT CRYSTAL CLEAR GLASS / METAL BACKSIDE HIGH INTENSITY LED BULBS (4) LOW/HIGH BEAM HEADLIGHTS NO MODIFICATIONS NEEDED - PLUG AND PLAY LED HEADLIGHTS PART NUMBER INTERCHANGE: H5006 / H5001 OR 4000 / 5001 DOT SAE APPROVED LED BULB SPECIFICATIONS: Bulb Type: - Generation 5 - H4 (9003) LED Low Beam / High Beam Headlight with Canbus Error Canceller Plugs Canbus Error Free Electrical plugs prevent any headlight error codes Wattage: 40W / EACH PC Luminous Flux: 8000LM / Set ,4000LM / Each Bulb Beam Angle: 360? Placement on Vehicle: Left, Right, Front Color Temperature: 6000K Pure White THIS LISTING IS FOR A NEW SET OF 5 3/4" CRYSTAL CLEAR GLASS LENS - METAL BACK HEADLIGHT BULBS. THIS SET INCLUDES (4) LOW/HIGH BEAM HEADLIGHTS WITH HIGH INTENSITY LED LIGHT BULBS (NO WIRING OR BUCKET MODIFICATION NEEDED). THESE HAVE THE ORIGINAL SHAPED PRONGS ON THE BACK SO THEY WILL PLUG RIGHT INTO YOUR ORIGINAL WIRING HARNESS PLUGS. THESE PLUG AND PLAY LED HEADLIGHTS WILL FIT ANY CAR OR TRUCK THAT HAS 4 ROUND GLASS HEADLIGHTS. WILL FIT INTO STOCK BUCKETS. EACH BULB IS 5 3/4 INCHES IN DIAMETER. THIS H4 LED HEADLIGHT KIT IS GLASS AND WE WILL TAKE EXTRA CARE IN PACKAGING. DOT SAE APPROVED INTERCHANGE: H5006 / H5001 OR 4000 / 5001
OK People, Thanks.
I'm not into the halo's, AND, the BOSS said "NO".
It was just an Idea..............
Have a Great Day,
Bill
http://www.thesamba.com/vw/forum/viewtopic.php?t=482756" onclick="window.open(this.href);return false;
And the New One https://www.corvetteforum.com/forums/c3 ... storm.html
Bill
