Flywheel noise
MORTUNDEAD
Flywheel noise
Unread post by MORTUNDEAD » Mon Apr 22, 2013 7:50 am
Almost everything is finished on my '62 monza 900. However, it still has a horrible rattly flywheel. How big of an issue is this? Can i just replace the rivets with bolts? Or is it even a big deal? If the main issue is just the sound, i can deal with that. But i need the car to be reliable, so if this flywheel needs replacement i will do it.
1962 Chevrolet Corvair Monza 4-speed 80 h.p. over a million documented miles !
Re: Flywheel noise
Unread post by bbodie52 » Mon Apr 22, 2013 9:46 am
The problem you described is most likely a loose flywheel. The Corvair flywheel is riveted to a flex plate when it was manufactured by Chevrolet. Over the years these rivets can loosen as the car is driven, producing a loose flywheel attachment. This produces a rattling sound when the engine idles with the transmission in neutral. Applying any pressure on the clutch pedal moves the throw out bearing into contact with the diaphragm spring on the clutch assembly pressure plate. This has a dampening effect on the assembly, and usually silences the rattling sound that you hear. The sound will resume immediately when the driver removes his foot from the clutch pedal. Unfortunately, there is no easy solution. The only way to fix this is to remove the powertrain from the car and separate the engine from the transaxle to allow the flywheel to be removed and replaced.
Do the symptoms I described match the symptoms in your Corvair? Repairing a loose flywheel in your Corvair is not a small job, so you want to be absolutely certain when troubleshooting the problem that the symptoms are from a loose flywheel and not from some other source. If you perform the repair you should completely examine the clutch assembly for excess wear or other problems. The condition of the pressure plate, clutch disc, and throw out bearing should also be checked, and any worn components should be replaced. The input shaft seal should also be replaced, and the crankshaft seal should be checked for oil leaks. The throw out bearing shaft that protrudes from the differential should be carefully examined for cracks or damage, as damage to these components can occur, and the crack can result in an oil leak from the differential. If you are doing this work yourself, be very careful when separating the transaxle from the engine. The input shaft is long and may remain embedded in the clutch disc as you separate the two components. If this happens the other end of the splined input shaft may pull free from the transmission. When the two components are separated by several inches you may be able to reach between them and pull the input shaft from the clutch assembly. It is important to maintain the alignment of the engine and transaxle so that the input shaft does not act like a lever against the differential throw out bearing shaft, because such leverage against the throw out bearing shaft could potentially cause damage to the throw out bearing shaft or to the input shaft if it is bent. A damaged throw out bearing shaft can only be replaced by completely dismantling the differential.
I have attached a Chevrolet guide that explains procedures for removing the transaxle from the car. Removing the transaxle is usually done with a service station type hydraulic floor jack. I usually use a sheet of three-quarter inch plywood to protect the underside of the powertrain from the lifting surface of the floor jack. Once the powertrain has been lowered to the ground the engine can be separated from the transaxle. If you're going to do this job please review all of the procedures in the factory shop manual prior to starting the work. It is always a good idea to have one or two assistants with you to help you to carefully lower the powertrain from the car.
Corvair and Corvair 95 Power Train Removal & Installation.pdf
(3.35 MiB) Downloaded 100 times
Here are some pages from the Clark's Corvair Parts online catalog. These pages explain the rattling sound you hear from your Corvair clutch. They also list several replacement part options. The last two pages illustrate the input shaft and throw out bearing shaft.
Simply click on the URL displayed above each image to go to the actual website. Clicking on any part number will display costs and availability.
http://www.corvair.com/user-cgi/catalog ... N&page=109
http://www.corvair.com/user-cgi/catalog ... N&page=110
http://www.corvair.com/user-cgi/catalog ... N&page=124
http://www.corvair.com/user-cgi/catalog ... N&page=128
From Corvair Underground http://www.corvairunderground.com/
Corvair Underground wrote:THE ENGINE MAKES A HORRIBLE RATTLING NOISE - yes, I realize that you think you have rod bearings going out but this is rarely the case. First, remove the fan belt and run for a short period of time. If the rattle goes away you can be pretty sure that the blower bearing is bad. That not being the case the next thing to suspect is a bad flywheel. A positive test is to let the engine idle in neutral and slightly depress the clutch pedal - if the rattle goes away or changes then you have bad rivets in your flywheel and it must be replaced with a new bolted unit Sometimes there is no rattling but a lot of vibration.
Re: Flywheel noise
Unread post by cad-kid » Mon Apr 22, 2013 4:33 pm
Good plan on replacing the flywheel. Somethings it's better to get it done right.
CORSA Member#031129
MORTUNDEAD
Re: Flywheel noise
Unread post by MORTUNDEAD » Tue Apr 23, 2013 7:49 am
Yes im sure the flywheel is the issue. Has exactly the symptoms of a loose one. Is it bad to just replace the rivets with bolts? I've seen it done before with decent results...
Re: Flywheel noise
Unread post by bbodie52 » Tue Apr 23, 2013 10:01 am
If you look at the first two pages that I posted from Clark's, you will see numerous options discussed and offered there, including stock, re-riveted, bolted, solid, and tapered bolt, as well as DIY bolt kits. As to which is best or most-economical? I could not say, since I only had to replace one loose flywheel, and that was back in 1980. :dontknow:
Bobby65
Re: Flywheel noise
Unread post by Bobby65 » Tue Apr 23, 2013 12:30 pm
On mine i just took an air chisel and pushed the rivits out and put in a grade 8 bolt and red locktight and prick punched the ends, do this one rivit at a time and you should be good, unless the holes are elongated
Drive it like you stole it
65 Turbo Monza Coupe
64 monza convertible 4 spd
Grand Ledge, Michigan
Re: Flywheel noise
Unread post by UNSAFE » Thu Apr 25, 2013 2:56 pm
If you are trying to save some money and you have the time , go ahead and try it .
Not really much to lose except time if you have to redo it.
BobFarrell
Re: Flywheel noise
Unread post by BobFarrell » Sun Dec 21, 2014 11:02 am
I am afraid I may have a similar issue but would like confirmation from the experts before I begin the repair process.
My fan belt broke (unbeknownst to me) and I suspect I drove between 10-20 miles this way before getting home. I changed the oil (as it smelt burnt) an installed a new belt. Upon my next start-up, I heard a terrible rattle that is only there upon idle. With some gas, it goes away. Obviously, this is something I want to correct before placing any additional miles on the car.
I disconnected the fan belt to see if it was the fan bearing. No such luck as the noise is still there. My issue with the explanation for the others is that my car is an automatic. Therefore I do not have a manual clutch. Any recommendations on a 62 Convertible automatic (with a 65 engine)???
Thanks!
Bob
Goodyear, AZ
Grandpacorvair
Re: Flywheel noise
Unread post by Grandpacorvair » Tue Jan 06, 2015 6:11 pm
Have you had any luck with this?
IF it weren't for the 10-20 mile drive with no belt and the resultant burnt oil smell, the sound you are hearing MIGHT be a broken flex plate..
However given the circumstances I suspect you may have done some significant damage to the engine...A compression test MIGHT give a hint as to the engines present condition but a tear down may be the best way to go....
Best of luck,
Kerry
Kerry Borgne
1963 Spyder Convertible
Birmingham, Michigan
BobFarrell
Re: Flywheel noise
Unread post by BobFarrell » Tue Jan 06, 2015 6:55 pm
Thanks. However as stated above, the issue with the noise was 2 loose bolts on the flywheel and accessed by removing the rear engine shroud. Upon tightening these bolts, the noise disappeared.
I was concerned about possible engine damage. I checked compression (as you also recommended). There was no significant difference in any cylinder.
I am absolutely certain I was VERY lucky in this circumstance.....
Thanks for your suggestions and participation on this site.
Bob
Re: Flywheel noise
Unread post by azdave » Wed Jan 07, 2015 7:08 am
BobFarrell wrote:Thanks. However as stated above, the issue with the noise was 2 loose bolts on the flywheel and accessed by removing the rear engine shroud. Upon tightening these bolts, the noise disappeared.
This might be confusing to anyone new to Corvairs so I'm replying in order to clarify since there are two different noise problems presented within this thread (Manual vs. Automatic)
Bob,
More correctly it sounds like you fixed the problem by tightening two of the three bolts that connnect the flex plate to the torque converter. An automatic does not have a flywheel so the solutions offered above to MORTUNDEAD about fixing flywheels with hot rivets or special bolt sets do not apply to anyone with a flexplate.
How about the original poster (MORTUNDEAD) in this thread? Did you get your flywheel problem fixed? I dropped the power pack in my 65 Corsa yesterday because of this same issue. It still has the original flywheel and rattles like mad when the clutch is not depressed and is really noisy when the clutch is out with the tranny in neutral. I've got a new (old) Dale repair flywheel ready to install.
65 Corsa 140 4-speed
66 Corsa 455 Toro V8
65 Monza 455 Toro V8
65 Monza 4DR EJ20T w/5-speed
DAVECS1
Re: Flywheel noise
Unread post by DAVECS1 » Wed Jan 07, 2015 7:43 am
I have a post on here somewhere, basically I had all the bad flywheel and clutch symptoms. I looked at parts piece by piece, but my end goal was to put some miles on this car. In the end I went ahead and ordered Clarks deluxe kit. Seems pricey, but you get directions with all the tips and tricks attached to each piece and they give you money for your old parts. The best part is all the parts are there and go together with no hassle, and my car has been trouble free in that department for 7200 miles. If you want to do it o ce that is the investment I would make.
1964 Monza Convertible
110 4 Speed
Re: Flywheel noise
Unread post by bbodie52 » Wed Jan 07, 2015 11:20 am
When replacing your clutch, I would caution you to be careful when separating the engine from the transaxle.
:wrench: The problem with the manual transaxle is that the long input shaft (23-24 inches) tends to remain embedded in the pilot bushing and clutch disc, while the other (smaller) end of the splined shaft pulls free from the transmission. As the two heavy components separate, any misalignment that is permitted risks leverage being applied by the input shaft against the throwout bearing shaft, which can fracture this machined casting. Replacing a damaged throwout bearing shaft requires dismantling the differential.
Even if you remove the powertrain as an assembly, use caution when separating the heavy transaxle from the engine. If the input shaft remains embedded in the clutch, you must pull the transaxle straight back about 24 inches until the other end clears the transaxle. If you have an assistant, the assistant may be able to reach between the differential face and the bell housing to grab the input shaft and pull it free from the clutch assembly — reducing the risk of damaging the input shaft, clutch disc, or throwout bearing shaft.
With the engine and transaxle separated, be sure to inspect the throwout bearing shaft completely for cracks or fractures. The input shaft seal should be replaced when doing a clutch job, to ensure that no gear lube will leak onto the clutch assembly during operation. Also, when prying the input shaft retaining ring and seal out, be careful not to apply levarage against the end of the throwout bearing shaft, as excess leverage with a screwdriver or similar tool could conceivably cause a crack to form on the throwout bearing shaft.
Re: Flywheel noise
Unread post by azdave » Wed Jan 07, 2015 2:47 pm
bbodie52 wrote:When replacing your clutch, I would caution you to be careful when separating the engine from the transaxle.
I ran a broken snout (chunk missing) for years and never knew it. The seal and retainer inside was still in place and I had no clue it was broken until I did a clutch job years later. I suspect the previous owner was the culprit as I never found the missing chunk when I took it all apart. I guess they took the risk that it would be okay and put it back together that way. Seems they got away with it too. ::-):
