Aluminum Tensioner Pulley not compatible with factory A/C on a '66
- SethThomas
Hi everyone, It doesn't look like that the spring loaded pulley that is now sold by Ken Hand is not quite compatible with the factory A/C car as is (mine is a 1966). I figured this should be documented. I imagine this has not come up, as the factory A/C is kind of rare, and and people using the pulley is also uncommon.
If anyone knows Ken's handle on this site, can you add him? He probably should know.
I put the pulley on earlier this Spring. I noticed a week ago that there was a ton of metal shavings by the oil cap. I took a minute to notice the pulley had the scrape on it's left hand side. Turns out bounced enough to hit the U shaped bracket that acts at the base for the tensioner arm (very long bolt) on the A/C compressor.
I imagine one can modify the long tensioner bold and the place where it mounts to fix this issue. For me it finally put the A/C higher on "need to address" and I pulled everything out. The radiator was in a sorry state.
P.S. Does anyone cover the now open radiator vent with anything? Most I see leave it open, but I was thinking a mesh would help keep debris and mice out better.
Owned: 1966 Corvair Monza 110 with A/C
- American Mel
Re: Aluminum Tensioner Pulley not compatible with factory A/C on a '66
Radiator vent ? ? ?
You mean the cold air inlet?
That has a debris screen, it is the air-grill at the base of the rear window.
Otherwise, I have zero idea what you are talking about.
- SethThomas
Yes, that was what I meant. I called it that because that's where the radiator was sitting. It had a ton of debris behind it when I pulled it out. I figured the vent grille at the rear window base wasn't doing a great job.American Mel wrote: ↑Wed May 08, 2024 6:57 pm Radiator vent ? ? ?
However, thinking on it, it probably was decades of stuff, and the car is Garaged now. Maybe just leaving it is fine. Light sanding and paint is all I need.
- Frank DuVal
I put the AC in working order on my cars.
Yes, I try to glue a nylon screen over the vent behind the rear window, but it is not easy, as you cannot remove that vent without removing the rear window! (Backlite to those who know glass ) If the condenser (not a radiator) clogs then not only does the high side of the refrigerant go too high in pressure, but the engine is robbed of cooling air too!
Hey look, blue background!
- scooperman
when I had the backlight out I found a pile of leaves and dead lizards and whoknowswhat in the vent space, decided I wanted that vent panel to be removable without pulling the glass again.
I have the same screen name here. I have a spring upgrade that just may keep the idler more steady. I have posted several places about the extra spring but apparently you didn't see any of those posts.
I offer a dampener spring that goes on the inside of the original spring, it seems to help the oscillation quite a bit.
Ken Hand
248 613 8586
vairmech@aol.com
Corsa Past President
Corvanatics Vice Prez
Chair 2007 Detroit Convention
248 613 8586
vairmech@aol.com
- SethThomas
Sorry, I couldn't even remember your company name or email, for some reason I only remembered your name lol.vairmech wrote: ↑Thu May 09, 2024 4:00 pm I have the same screen name here. I have a spring upgrade that just may keep the idler more steady. I have posted several places about the extra spring but apparently you didn't see any of those posts.
A nesting spring may just do the trick. I don't look forward to removing this thing; it was a real bear to get on. Probably should be easier without the A/C bracket and bolt.
Be sure and send me an email with your address, all I am asking is $5 to help with shipping. The $5 is for those that have purchased from me.
If you want one for one of Lon's old idlers then it is $15 plus shipping. Also I offer a bushing upgrade to Lon's tensioners also.
Ken Hand
248 613 8586
vairmech@aol.com
248 613 8586
vairmech@aol.com
