New Member. 87 Octane gas
Re: New Member. 87 Octane gas
When I was in the Air Force, I was stationed at Hanscom AFB (in Bedford) from 1977-1980. Before we were assigned to base housing, I lived in Acton — about 71 miles from Belchertown. We loved living in Massachusetts. I really enjoyed bicycling from Acton through the historical areas in Concord as my wife and I rode through the beautiful back roads of Massachusetts. GREAT CORVAIR TERRITORY! (Not in the Winter... my first winter in Acton included the BLIZZARD OF '78 — not easy to adjust to as we were originally from Southern California). But we loved driving in New England in our 1965 Corvair Corsa (and in our 1973 Datsun 240Z). We loved all of the shows, concerts, and historical areas in Boston, too. My second son was born in Emerson Hospital in Concord.
1965 Corvair Corsa Convertible 140hp 4x1 - Spring 1980 - Base Housing - Hanscom AFB, MA
ahhhoo wrote: » Mon Apr 29, 2024 5:28 am
Thank you Brad.. We just picked up the car Saturday. Drove it home 30 miles to Belchertown Ma (our location). Next day, cleaning out the barn, the car just would idle choppy and would stall out at idle. Pushing the gas kept the engine running, but once off the accelerator, the engine would quit. To get the car moving again and moved into shelter, because of the rain last night, I turned each idle screw (without the syncing carb tool, its ordered.) 1.5 turns clockwise. The idle went up on the engine, but boy did it run rough!!! We limped it into the barn on where it sits now.
Is there any chance that you turned the IDLE MIXTURE SCREW clockwise, possibly getting it mixed up with the idle speed screw? Turning the idle speed screw clockwise on each carburetor would open the throttle butterfly valves (associated with the throttle linkage) and would increase the idle speed. If you mistakenly turned the idle mixture screws in 1½ turns, you would be cutting-off the fuel from the idle mixture, causing the idle mixture to be very lean.
bbodie52 wrote:There is no simple, or compressed method to tune and troubleshoot a Corvair engine. A certain amount of knowledge or understanding is essential for the person doing the tune-up to interpret the results and then to be able to make logical adjustments accordingly. I would encourage you to do your homework, ask questions for clarification when needed. and follow the guidance below and in the shop manual to ultimately get the desired results with your Corvair.
bbodie52 wrote:Here is a fair amount of tune-up info, but if you can work your way through it the explanations may help with your understanding of how the various subsystems interact with each other, and why the proper sequence should be followed so you don't end up adjusting one area improperly to compensate for another area that isn't functioning properly.
:think: The dwell tachometer and timing light are the most common items thought of when working with an older engine in a classic car. As previously mentioned, however, there are ways to work around the lack of these tools. Adjusting the ignition points gap with a flat feeler gauge is a substitute for having a dwell tachometer. Setting the dwell with an electronic instrument is more accurate, however. The tachometer portion is needed to measure idle speeds and possibly to perform other tests where engine speed measurement is needed. It is possible to static-time your ignition system with a strip of paper placed between the ignition points. The engine timing mark can be manually positioned to the desired setting on the crankshaft pulley, and the distributor can be slowly rotated until the points just start to open and release the strip of paper. The distributor is then tightened and the mechanic has established an initial static timing setting. Of course, having a timing light makes things much easier, improves accuracy, and permits visual confirmation that the centrifugal advance is functioning. A vacuum gauge can be used for carburetor synchronization and other carburetor tests, and most vacuum gauges also double as a pressure gauge for measuring fuel pump output pressure. A UniSyn gauge, as shown below, measures airflow through each carburetor throat, and is an accurate way for synchronizing multiple carburetors at idle speeds and at partial throttle. A multimeter is a useful tool for troubleshooting and diagnosing electrical and charging system problems.
Many ignition systems in Corvairs have been upgraded by fitting an electronic ignition system to the distributor. These electronic ignition systems eliminate ignition points and condenser, which makes engine tuning somewhat easier and eliminates the need to periodically replace worn ignition points. The breakerless ignition system utilizes an optical or magnetic trigger to control the ignition coil. The system eliminates the need for a dwell meter or flat feeler gauge for ignition points adjustments. (A wire-type feeler gauge is needed for adjusting spark plug gaps). The tachometer portion of a dwell-tachometer, however, is still useful.
:think: Learning to work with the two Rochester primary carburetors on the Corvair really isn't all that difficult. But you should take the time to review the shop manuals and other attached manuals to get a better feel for what you are trying to accomplish. It is important to perform tuning steps in the right sequence, as outlined in the shop manuals and in the video below. Many of the tuning steps can impact the results found in other steps. There is a logical progression in tuning a Corvair engine, and skipping around or tuning components in a random order can only serve to confuse the outcome. The Delco Rochester service manual that I have attached is a good supplement to the Corvair shop manual. About half of the manual is dedicated to explaining the various subsystems and components of the Rochester HV carburetor. To some extent these carburetors perform as you would expect a computer-controlled fuel injection system and ignition system to operate — but they were designed at a time when computer-controlled systems that were designed to respond to sensor input throughout the car would only have been a dream. The various carburetor and ignition subsystems respond to engine temperature, engine speed, airflow and vacuum changes, etc. much like a modern engine — but without all of the sophisticated electronics and sensors. Engineers were attempting to accomplish the things we do now, but with much less sophistication — but still making changes as engine speed, throttle position, engine vacuum, and fluid and air flow characteristics varied. If you take the time to read through the Delco Rochester manual, you might come to understand how the choke system functions, what an accelerator pump does and why it exists, and how the distributor is designed to adjust timing at low engine speeds and at higher engine speeds using both a vacuum advance and a centrifugal advance to provide the correct timing at various engine speeds and load settings. A good understanding of how these systems work and what they are supposed to do can be a great help when tuning and troubleshooting your engine.
The links, videos, and attachments below should help you to understand how to work with a dual carburetor engine. Try not to be intimidated by two physically separated carburetors. They really function very much like a single two-barrel carburetor, but are physically separated from each other out of necessity due to the layout of the flat air cooled engine with cylinders opposed to each other. The Corvair engine layout is in many ways similar to many motorcycle engine configurations. It usually takes an experienced automobile mechanic a little adjustment time to get used to the way things are done on a motorcycle. The aluminum, air cooled flat six Corvair engine often is seen as a challenge to an automobile mechanic, who is not used to the "strange configuration" found in a Corvair.
:link: http://www.corvairforum.com/forum/viewt ... 875#p90875
The entire shop manual and many other Corvair technical references can be downloaded at no cost using the following link...
:link: http://www.corvairforum.com/forum/viewt ... 225&t=6007
bbodie52 wrote: The Uni-Syn Carburetor Balancing Instrument is a tool that I remember as far back as the 1950s and 1960s. It was designed for use in multi-carburetor automobiles, motorcycles, etc. that were initially common in European vehicles, but were later found in American vehicles like the Corvair.
Image :confused:
:idea: The Uni-Syn is an airflow gauge that must be calibrated to match the specific engine airflow moving through the carburetor throat. The flow control in the center of the Uni-Syn is mounted on a threaded pin. Rotating the flow control raises or lowers it, which increases/decreases the air gap, which impacts the air velocity passing the oriface that allows some airflow to pass through the gauge. With the Uni-Syn held firmly on the carburetor intake with the engine idling, the flow control is adjusted so that the plastic float is approximately centered in the glass sight tube. Once calibrated, the Uni-Syn can be moved back and forth between the two primary carburetors to compare airflow at idle. The goal is to play with the idle speed screws to get an even airflow level that matches between both carburetors, and at the same time produces the desired idle speed. Before fine-tuning this idle balance with a Uni-Syn, the ignition system, idle speed and idle mixture should have been adjusted following the standard procedures as described in the factory shop manual. The balancing step with the Uni-Syn gauge is added at the end of the tuning procedure to measure actual airflow though both carburetors at idle, and balancing that airflow using the airflow meter as a measuring tool, rather than simply relying on a physical balanced "calibration" using a strip of paper to detect initial contact between the idle speed adjustment screws and the carburetor linkage, followed by counting the screw turns needed to obtain the desired idle speed (and ensuring that the same number of screw turns are applied to each screw). That procedure achieves a fairly close initial setup. The use of the Uni-Syn airflow gauge as a final step ensures balance between the two carburetors by measuring actual airflow.
:wrench: Once the balanced idle airflow and desired idle speed have been achieved, a similar procedure can be used to synchronize the airflow when the carburetors are held open at a faster engine speed by the throttle linkage. Again, the shop manual procedure can be used to set the initial mechanical balance between the two sides of the throttle linkage. The linkage segment connecting the accelerator pedal to the cross-linkage between the two carburetors is temporarily disconnected, and a turnbuckle is temporarily attached to hold the throttle opened against the pull of the throttle return spring.
Image :tu:
The turnbuckle can be adjusted to hold the throttle open at approximately 1500 RPM. The Uni-Syn center flow control is readjusted to re-calibrate the float to a position somewhere in the center travel of the sight tube, based on the increased airflow through the carburetors at the higher steady RPM maintained by the turnbuckle arrangement. As with the idle synchronization procedure, the re-calibrated Uni-Syn is used to measure the airflow moving through the two carburetors. The goal is to fine-tune the threaded portion of the carburetor actuation linkage so that the same airflow reading is attained on each carburetor, but this time with the throttles held open by a pull on the throttle linkage, instead of by the setting of the idle speed screws. When the airflow has been balanced using the throttle linkage adjustment, the balancing procedure has been completed and the normal accelerator pedal throttle linkage can be reconnected.
:tongue: Image ::-):
TIPS & CLARIFICATION...
Before setting the carbs, make sure that the ignition is right: points and timing set, good wires and plugs. Poor running is often blamed on carbs when in fact it's a weak, retarded spark. Check the throttle shafts: loose ones let in air and lean the mixture, raising idle speed, as well as throw off the linkage action. Check the linkage that connects the carburetors. if it's loose, one will open before the other. Make sure there are no vacuum leaks.
Once the carburetors are drawing equally at idle, hold an engine speed: at about 1500 RPM. This checks that the mechanical linkage is pulling equally. You'll need to open up the Uni-Syn center wheel to draw more air and bring the bead down in the tube. If both carburetors are within a bead's thickness of each other, that's good. If one is definitely off from the other, the higher flow carburetor's linkage is being pulled more than the other. You'll need to figure out why that's happening mechanically to rectify it. :chevy:
:goodpost: You need to backtrack a little...
The goal is normally to try to match the left and right carburetors as closely as possible. Rebuilding or replacing one carburetor while neglecting to do the same on the other side encourages something of a mismatch.
After checking for vacuum leaks (don't forget the Powerglide transmission vacuum modulator as a possibility), disconnect and plug the vacuum advance line that is coming from the right carburetor. (Make sure that the rubber hose is connected to the vertical vacuum tube on the right carburetor, and NOT the horizontal vacuum tube, which should be connected to the choke mechanism vacuum break unit on each carburetor). Temporarily readjust the carburetor idle speed screws to get the engine idle slowed down to about 700 rpm in NEUTRAL. This will ensure that the centrifugal advance mechanism in the distributor is not affecting the timing. Then recheck the points (dwell) with a dwell-tachometer and then the base timing setting with a timing light, and set them correctly for your engine, using the specs in the shop manual.
See Vacuum gauge viewtopic.php?f=225&t=10563
At this point, you will have confirmed that there are no vacuum leaks, and that the ignition system settings (dwell and timing) are correct. Reconnect the vacuum advance tube between the right carburetor and the distributor vacuum advance mechanism.
Following the procedures in the shop manual, the base (starting point) idle settings on each carburetor are to be established. With the throttle linkage at both carburetors disconnected from the cross linkage between the two carburetors, a narrow strip of paper is used like a feeler gauge by placing it between the idle speed adjusting screw and the carburetor throttle linkage. With the throttle closed, the idle speed screw is slowly backed away until it just releases its grip on the strip of paper. This establishes its point of contact with the throttle linkage. Then carefully turn the screw clockwise an a additional 1-1/2 turns to establish the idle speed preset. Perform this same procedure on the other carburetor. Then perform the idle mixture preset on both carburetors by gently turning the idle mixture screws all the way in so they just bottom-out in the carburetor. Then back each screw out counterclockwise 1-1/2 turns.
With the engine running, the correct idle speed for your engine must be established. With a manual transmission-based engine, the idle speed is set to the speed designated in the shop manual. This can be a starting point with the automatic transmission-based engine as well. Any adjustment made to increase or decrease the idle speed must be duplicated at both carburetors, so that the carburetor settings remain in sync on both sides. (A uni-syn gauge, or a vacuum gauge, if available, can be used to more-accurately synchronize the two carburetors so that they are each contributing an equal amount of airflow to the engine idle). With a Powerglide-based engine, the final idle speed must be set with the transmission in DRIVE, to load the engine with the resistance provided by the fluid coupling (torque converter). The goal is to achieve a slow, smooth and steady idle speed in DRIVE.
:wrench: Image :woo:
With the carburetor idle settings in sync, and the correct idle speed established in DRIVE, the last step is to reconnect the main throttle linkage between the two carburetors, and then the throttle linkage connection to the accelerator pedal. These procedures are described in the shop manual. There is an adjustment point in the linkage on the left side. The goal is to have both carburetors connected to the cross-linkage, without the linkage binding or holding either carburetor throttle open or impacting the idle speed. The link on the left carburetor is adjusted so that bot the right and left carburetor connections slip into the cross linkage. Finally, the adjustable link and throttle return spring is adjusted to slip into the cross link without changing the idle speed, so that the gas pedal permits opening the throttle fully but also allows the throttle to return fully to the idle setting.
:chevy:
1965 Corvair Chassis Shop Manual - SECTION 6 - ENGINE TUNE-UP.pdf
(2.92 MiB) Downloaded 3 times
(8.87 MiB) Downloaded 3 times
1965 Corvair Chassis Shop Manual - SECTION 6Y - ENGINE ELECTRICAL.pdf
(8.51 MiB) Downloaded 3 times
1965 Corvair Assembly Manual - CARBURETOR & FUEL SYSTEM.pdf
(3.92 MiB) Downloaded 3 times
1965 Corvair Assembly Manual - ELECTRICAL COMPONENTS, HARNESSES & SCHEMATICS.pdf
(12.21 MiB) Downloaded 3 times
1965 Corvair Assembly Manual - FUEL AND EXHAUST SYSTEMS.pdf
(2 MiB) Downloaded 3 times
DELCO ROCHESTER - Models H, HV Carburetor Service Guide.pdf
(1.79 MiB) Downloaded 3 times
ahhhoo
Post by ahhhoo »
Thank you for the responses. I talked to the previous owner and he mentioned that exact brass inline filter. He explained where the location is, but since I was in my car fuming that the RMV declined my registration today, after waiting 2 hours, I didn't follow him exactly on where to look. I assume its the line going into the fuel pump? I am going to try to clean (blowout and eventually replace) this with the WIX 33050. Thank you, thank you, thank you... Fingers crossed.
ahhhoo
Post by ahhhoo »
On the carb inlet...
There are sintered bronze fuel filters located in the carburetor inlet, behind the large nut that the fuel line screws into. There is a spring located behind them, and when they get clogged, the fuel pressure pushes them inward to allow the fuel into the carburetor. It is important to change these filters, since presently, they are your only line of defense to keeping dirt out of the carburetor. I don't like inline fuel filters that connect with a short piece of rubber, because of the associated risk of fire.
ahhhoo
Post by ahhhoo »
I removed the two brass filters, sprayed carb cleaner all over it and blew them out with my air compressor. No improvement. Runs real rough, like starving for fuel and dies. I will buy some WIX filters later.
American Mel
Post by American Mel »
ahhhoo wrote: Mon Apr 29, 2024 1:10 pm I removed the two brass filters, sprayed carb cleaner all over it and blew them out with my air compressor. No improvement. Runs real rough, like starving for fuel and dies. I will buy some WIX filters later.
Did you check that the carbs ARE getting fuel?
Did you look down the throats while the engine is running?
You can check for fuel by flicking the throttle and watching for a fuel shot from the accelerator pump hole.
RexJohnson
Post by RexJohnson »
It sounds like the idle circuit is the problem. I would remove the mixture screws and then blow out the passage with compressed air. Reinstall the screws and gently seat them. Then back them out 2 turns and see how it runs. If it seems to be running good when warmed up then fine tune as needed.
:goodpost:
LET ME REPEAT MY EARLIER QUESTION...
ahhhoo
Post by ahhhoo »
Thanks brad for all your info. Lots to go through! Yes Massachusetts is beautiful and its funny you know where Belchertown is. I am sure most Massachusetts residence don't know where we are. I hope one day I can say that I loved driving around Rt 2 and the Berkshires in our Corvair. Feeling overwhelmed now.
The vacuum lines look good and snug. The carbs are getting jets of fuel into the chamber.
I did notice that the two butterfly valves were not lined up. One was fully open and the other, maybe a 3/4 or 1/2 open. The carbs were rebuilt.
ahhhoo
Post by ahhhoo »
Bbodie52, thanks for inquiring. I absolutely did not touch the mixture screws. The idle screw are near the linkage, plus I watched that youtube video from BIG AL.
Hah... just figured out how to edit my posts :).
erco
Post by erco »
I made the same mistake in 1980. Driving home on day 1 after buying my '67 Monza 140, I cheaped out and filled it up with regular gas (whatever the octane was in 1980). The seller did say premium only but I was young, dumb, and broke. Almost made it hope before she started pinging & sputtering. Had to transfer all that gas to Dad's car then bring 5 gallons of premium home in a gas can. Live & learn!
Best premium we can get now in California at most stations is 91 octane. Except for one station, VP Racing fuels which claims to have 101 octane. I think that gas is always $9.99/gallon, that might be a limiter, the maximum the pumps can go.
I keep thinking of trying some 100 octane low lead Avgas from the airport. I could just siphon it out of my Cessna. :)
Post by Frank DuVal »
The inline filters like the WIX 33032 go in the fuel line either at the tank or behind the left rear wheel. No risk of fire. DO NOT mount them in the engine compartment!
The WIX 33050 mentioned are the sintered brass filters.
The 33032 is the 5/16" inlet and outlet metal cans for in the fuel line under the car, as noted.
:tu: :chevy: :tu: :chevy:
Have you done the Corvair specific carburetor dirt suck through? With it running, as poor as it might, revthe engine up and cover one carburetor with your hand, then do the other. You might also find one being covered does not kill the engine, while the other one does. With your hand over the carburetor (running on the other) lay into the throttle then release your hand, backing down the throttle as it picks ups speed. Has been know to suck lots of problem dirt out of carburetors! :tu: :tu: :tu: :tu: :tu:
Single carburetor cars cannot do this troubleshooting method, to bad. :rolling:
ahhhoo
Post by ahhhoo »
Morning.. I got a surprise phone call last night from the seller of the Corvair to check in, which was real nice. He was in disbelief on the idle issue. Talking it over, he is adamant its the bad gas issue. He also took away my flat screwdriver privilege, meaning keep my hands off the engine til I remove the gas and refill it. Talking to him gave me some hope. Because of work, this will take a while to do. Want to thank everyone with their input and taking your time to respond. Looks like a great group here.. Thanks to Bbodies52 for all the great info! I truly hope I can enjoy a relatively trouble free summer with this car and start studying all that info at a slower stress free pace this fall and winter. Fingers crossed
I will let you know when I empty the gas, hopefully this weekend, and give you updates.
-al
Unless you KNOW exactly what is wrong, I would suggest that you obtain the needed tools and begin learning the correct tune-up procedures outlined in the videos I posted, and covered in the shop manual and other references I attached to my earlier post.
An experienced Corvair tuner and mechanic might be able to analyze what is going on and quickly, and accurately make a corrective adjustment. But you are new to Corvairs and lacking an experience guide to assist you, I would recommend you follow the videos and shop manual and test and tune the engine from the beginning steps, and then work your way through the ignition and carburetor tests and adjustments in the specified order. The various adjustments often impact each other, and the overall outcome can't be successful if you randomly jump around and make random adjustments without knowing the overall impact on engine operation. Follow the sequential steps outlined in the Chevrolet tune-up videos. If you reach a barrier that does not make sense to you, there may be an undiscovered fault in a defective component that needs further investigation and troubleshooting techniques. That may be a time where you need to jump on to the Corvair Forum to discuss your trouble or confusion with other experienced Corvair owners. The trial and error approach may be slow, but as you make progress you should be gaining understanding and knowledge that will help you to see what is happening with your engine in a way that will make sense to you.
It is nice the seller called, BUT I have to agree with others here, the gasoline you bought should not have caused an idle problem due to octane. Lower octane fuel will "ping" under throttle (load), but has no effect at idle. It is possible there was debris in the new fuel or it stirred up something in the tank
As Brad said you need to stop "guessing" and "throwing parts" at the problem. One of the major deterrents to owning an old car is finding a good mechanic or technician who knows the car.
About the idle circuit. The cluster in the carburetor has a small tube that sits in the fuel well and at the bottom of the tube is a VERY SMALL opening that controls the idle fuel flow. Tiny debris will plug up the idle tube opening. The carburetor fuel filters will not trap "tiny" debris - hence the need for a good fuel filter in the fuel line.
First things first --- I would check the ignition setting dwell and timing. Next I'd check the fuel pressure should be 4-5PSI. I'd make sure all the spark plug wires are seated. If those are good I'd swap out each carburetor with a known good unit to see if that fixed the issue.
ABOUT UNPLUGGING THE IDLE CIRCUIT -- I DO NOT RECOMMEND THIS DUE TO POSSIBLE PERSONAL PHYSICAL INJURY!!! In the past folks have briefly covered the carburetor opening with their hand at idle and this has been reported to pull debris out of the idle circuit and the car runs fine. This fix had been posted over the years, but it is potentially dangerous as the vacuum can damage your hand.
Vacuum damage? Carburetor backfire flame damage maybe, but vacuum? Please tell of cases of this. I'm always willing to learn of safety issues. :tu:
Hint, never cover a carburetor with your hand if it backfires (lean condition will cause backfire in throat of carburetor, easy to see with air cleaner off and reving engine, and typically we are addressing lean conditions with this fix)! :eek:
Anotherbig issue I never see addressed is never blip throttle by grabbing the cross shaft above the fan. I know, real easy to grab that raised section, but, it is real close to the belt and fan pulley. Yep, lost some skin against the pulley one day with an engine and stuck throttle. Fast skin removal. I always now grab the throttle linkage on carburetors to blip the throttle, typically the left carburetor. :tu:
Oh, and the fix works many times, maybe just temporarily, but then you know what is wrong. Dirt in some carburetor orifice. Usually a Nitrile glove does not come off/tear if one wears one. Of course a leather glove will work nice too, and protect one's hands. :tu:
And, yes, good quality (not water/rust/old) 87 octane will start and idle just fine in the engine. I would take the fuel line off the left carburetor, stick it in a clear "pop" bottle, crank the engine (of course it will start!, so stop it immediately!!!) and then inspect the fuel in the bottle for rust and water. For more safety you can slide a proper sized rubber hose over the end of the fuel line and place the bottle out of the engine compartment. It only takes an ounce or two to see fuel quality in the bottle. For more safety, remove the wires on the + terminal of the coil. This prevents sparks and engine starting. Do not just take the coil HV lead out of the distributor cap center tower and place it on engine sheetmetal ground. That makes sparks, a big NO NO in this test!
:eek:
Dennis66
Post by Dennis66 »
ahhhoo wrote: Mon Apr 29, 2024 2:12 pm I did notice that the two butterfly valves were not lined up. One was fully open and the other, maybe a 3/4 or 1/2 open. The carbs were rebuilt.
Did nobody else see this? If one is WOT and the other is only 3/4 throttle there is definitely an adjustment / syncronization issue. One side (right or passenger IIRC) is fixed with a one piece rod. The other side (driver) has an adjustable swivel. Disconnect the clip check with a flashlight that both chokes and fast idle cams are completely open, and both butterflies are shut. Then adjust the linkage swivel to fit into the hole.
Dennis
