I found these plugs at my shop.
Can I use them in my 110 PG?
Thanks,
Tom
NGK 3722 BR5HS
NGK 3722 BR5HS
64 Monza Vert
64 Spyder Vert
64 T-Bird
64 Spyder Vert
64 T-Bird
- Phil Dally
Re: NGK 3722 BR5HS
5's do work good in a naturally aspirated engine...6's are better.
Used 7's in my turbocharged racecar and Dwight uses 9's in his.
No more than the 6's recommended in anything on the street.
Vairy V8 Rides Again.
LA Angels fan since 1978
Only Own 10 Corvairs Today
Been Associated With Fifty!!
Re: NGK 3722 BR5HS
With NGKs a lower number is a hotter plug.
I use BR6HS 3922 in 102,110,140,150 and 180 Like AC44.
I might use BR5HS in a 80 or 95 like AC46.
CorvairRepair.com
CorvairRepair.com
