Removing Torsion Bars For Trunk
I need to clean the area under the torsion bars for the trunk.
Is there a lot of pressure on the bars?
Do I need to do anything special to avoid problems.
Larry
Larry
Re: Removing Torsion Bars For Trunk
There is a fair amount of pressure on the bars. You didn't say for an early or late as they are a bit different but similar. You have to hold the lid all the way up as this relieves some of the tension.
On the early they are somewhat exposed and I think I used a 1/2" piece of pipe.
I've done the lates but it has been a long time since I have had to get in there so I can't tell you about it.
Keep in mind that the lid gets pretty heavy and if you are not careful the rods can bite you!
Ken Hand
248 613 8586
vairmech@aol.com
Corsa Past President
Corvanatics Vice Prez
Chair 2007 Detroit Convention
248 613 8586
vairmech@aol.com
- Frank DuVal
Yes, a lot of pressure. Enough pressure to push up on the lid from a very short lever arm.
Procedure in shop manual.
Here is early, you did not state what car you are working on:
FRONT COMPARTMENT LID TORQUE RODS
Removal
1. Open front compartment lid.
2. Prop lid in extreme up position.
3. Place end of large screwdriver or other suitable
tool at base of torque rod retainer immediately
behind tabs shown in Figure 10-15. Insert block of
wood, the approximate width of retainer opening,
between shaft of screwdriver and ends of both
torque rods immediately below torque rod attaching
pin; then carefully pry block rearward to take
tension of torque rods off pin and remove pin.
NOTE: Mark pin retaining hole prior to removal
of pin to insure rods are installed in same
position.
CAUTION: Exercise care when releasing tension
from rods after removal of pin as torque rods
may be under considerable tension.
4. Disengage each torque rod from movable portion
of affected hinge and remove rods.
If you do not have a shop manual, you can look at early or late online at the corvanics website. But I suggest you buy the proper one because the online pictures are poor.
Removal
position.
Hey look, blue background!
- Frank DuVal
Removal
position.
Removal
position.
1965 Corsa Convertible
Covered on page 3-12 of the attached 1966 Fisher Body Service Manual - SECTION 3 - FRONT END
FRONT COMPARTMENT—CORVAIR is on page 3-11 - 3-14.
https://ssl.corvair.com/user-cgi/catalo ... w_page=244
Part number C3718: BOOK-65-69 BODY SERVICE MANUAL
Weight: 1 lbs 0 oz
Catalog Page(s): 244
Price: $ 11.95
BODY SERVICE MANUAL '65-69
Over 100 pages. Covers items not in regular Shop Manuals and Assembly Manuals. Alignment of hoods, doors, repair of windows and mechanisms, headliners, pages on installation of tops, body lubrication, how to remove moldings, body align ment dimensions, sealing leaks. Full of pictures and diagrams and much more (minor details may vary for some years).
Weight: 1 lbs 0 oz
Price: $ 11.95
- 1966 Fisher Body Service Manual - SECTION 3 - FRONT END.pdf
- (3.94 MiB) Downloaded 8 times
It on a 65.
Looks like I need a lot of planning. I thought I could remove the screws that hold the rods but that does not appear to be the case.
Thanks for the help. Larry
Well I did it. Not exactly how the manual described it but worked well and safely. I also figured out how to put them back on.
Larry thanks for the help.
