Parts car body tag
- The_Cat_Of_Ages
Parts car body tag
I cant find the vin plate, (this is a 1964 spyder) but heres the body plate.
It's not the rate of speed that matters, it's how scary it is to get it there.
- Phil Dally
Re: Parts car body tag
VIN tag should be on the drivers side door jamb.
Tack welded in place...not riveted or screwed!!
Vairy V8 Rides Again.
LA Angels fan since 1978
Only Own 10 Corvairs Today
Been Associated With Fifty!!
I just bought a 1962 Greenbriar van. I found a plate in the driver's door jam that gives a 12 digit number. I found the original California registration, it says it is the engine code. I don't see another plate for the VIN #
- caraholic4life
IF the plate you saw in the Driver side door jamb looked something like 2R126F100000 it is the V.I.N. for your Greenbrier.
It should be spot welded in place, not screwed on.
Also if you look at the frame rails at the front of the van, you might be able to see the V.I.N. stamped into it.
Prior Kelmark Owner
Prior Kelmark Owner
- caraholic4life
Here is a photo of a 1962 Spyder Convertible VIN Tag from a current e-bay listing.The_Cat_Of_Ages wrote: ↑Fri Nov 24, 2023 11:04 am I cant find the vin plate, (this is a 1964 spyder) but heres the body plate.Screenshot_20231123_161806_Facebook.jpg
It is located in the driver's side door jamb.
- Early VIN Tag2.jpg (64.96 KiB) Viewed 204 times
Prior Kelmark Owner
Prior Kelmark Owner
