Hello, got a '66 Corsa, what does this body tag tell me?
jberd45
Post by jberd45 »
So a couple of weeks ago I bought a '66 Corsa. Pretty rough shape, I don't have any other pictures except the body tag.
It has the 140 horse engine, black interior, the worst yet thorough paint job I've ever seen and more rust than the guy I bought it from let on.
Re: Hello, got a '66 Corsa, what does this body tag tell me?
BODY TAG INFO:
10C
Body Build Date: 10 = October (1965) C = Third Week
The first two digits are numbers 01 through 12, indicating the month of manufacture. The letter is A-E, indicating the week of the month. If the letter is a "C" it indicates the third week of the month.
E
Interior paint codes: (Interior paint codes do not appear on Los Angeles built cars)
1966: F= Fawn T= Turquoise S = White/Black D= Red R= Bright Blue
E= Black Z= Bronze.
ST 66-10737 WRN 1571 BODY
Style: 66 = 1966 10737: 1 = Chevrolet, 07 = Corsa, 37 = 2-Door Coupe 4-Passenger,
WRN = Willow Run, Michigan, Production Sequence No: 1571
1966 Chevrolet Corvair Corsa 2-Door Coupe - 4 Passenger, Total Production: 7,330
TRim: 758- = BLACK (MONZA 10500 and CORSA 10700 SERIES — Bucket Front Seats)
This 3 digit code represents the interior color and seat type.
Paint: M-M = AZTEC BRONZE "Aztec Bronze"
Lucite No. 4707L, Rinshed-Mason No. A1817R, Ditzler No. DDL 71525
Example — 1966 Corvair Corsa Coupe in Aztec Bronze
Late Model (1965-1966) Corvair Corsa Turbo Exhaust Cutout
ACC = Accessory line
W 2LP 3C 4PU 5W
GROUP 1
NONE
GROUP 2
NONE
GROUP 3
NONE
GROUP 4
O = RPO L87 — 180hp Turbocharged engine
GROUP 5
NONE
:chevy:
1966-Chevrolet-Corvair - GM Heritage Center Specs.pdf
(1.78 MiB) Downloaded 9 times
jberd45
Post by jberd45 »
Thank you for the info. I had a suspicion what I've bought was supposed to be a turbo car; unfortunately for me it currently isn't. Somebody swapped in a 140 engine, which isn't bad but that makes this whole project a lot more expensive.
