Racing Chassis Using Corvair Crossmembers
Autocross, Landspeed, Drag Racing, Road Racing, Other Driving/Racing topics
California Racer
Post by California Racer »
Here is a pic of a little drawing showing the goal of laying out foundation of chassis.
You locate the bottom longitudinal tubes at a height from the ground.
Then you locate the crossmembers the same way.
It is a matter of connecting the crossmembers to the frame.
Designing and building upright pieces. Then making them and welding it all together.
From then on you are basically 'hanging on' the rest of the race car.
Racing Chassis Corvair Crossmembers.png (10.27 KiB) Viewed 2581 times
THE CALIFORNIAN
erco
Re: Racing Chassis Using Corvair Crossmembers
Post by erco »
Not much detail there to go on, partner.
California Racer
This is a really old post!
Best thing I can say is use the trial and error method.
This is a guide not a set of plans.
Get some 1" square 1/16" wall steel tubing and a quarter sheet of 1/16" thick sheet metal.
Build a mule frame to work out all the dimensions.
Will post a simple top view drawing of a two seater frame.
When done with mule frame duplicate it in final size tubing.
Cut off the mule tubing and sheet to keep around shop for building stools or tables.
Hope this helps.
Simple Corvair Chassis.png (11.47 KiB) Viewed 1433 times
THE CALIFORNIAN
Return to “Flaps up, Balls out!”
