Help on how to remove ....
Any advice on hoe to remove these inside hood fasteners?
Jeff Cannon, Smithfield, VA
1966 Corvair Monza Conv.
Jeff Cannon, Smithfield VA
1966 Corvair Monza Convertible
Re: Help on how to remove ....
It has been many years, but I believe they just popped out when I used a scraping tool to pry them away from the insulation. The metal fingers may break. You may choose to replace them with a plastic set as shown in the Clark's catalog. I couldn't find any mention of these clips in the 1966 Fisher Body Service Manual.
http://www.corvair.com/user-cgi/catalog ... &page=295B
Part number C4616 (Other): ORIGINAL 1965 STYLE METAL HOOD RETAINER FULL SET=C4616K
Note: This part is not a perfect match for C378.
Weight: 0 lbs 2 oz
Catalog Pages(s): 179,295B
Price: $ 3.45
Part number C378: 65-69 ENGINE COVER INSULATION RETAIN-EA SET 12=C378A
Weight: 0 lbs 1 oz
Catalog Pages(s): 295B
Price: $ 1.40
Part number C4616K: ORIGINAL 1965 STYLE METAL HOOD RETAINERS SET/12
Weight: 1 lbs 0 oz
Price: $ 35.85
Clarks repro insulation
http://corvaircenter.com/phorum/read.php?1,21711
Weight: 0 lbs 2 oz
Price: $ 3.45
Weight: 0 lbs 1 oz
Price: $ 1.40
Weight: 1 lbs 0 oz
Price: $ 35.85
Thank You!
A flat right angle carpenter's "Wonder bar" also works great. I have a smaller one in plastic for wiper arms and exterior moldings. Plus you already have a non-marring pad in place
I use a door panel puller tool. It works great.
Note: I have heard that the 65 metal retainers sometimes come loose and can be "eaten" by the fan. Not good. Many people use the 66-69 plastic retainers for that reason. Those plastic retainers often get destroyed when removing so get a few extras.
I used a small pair of needle nose pliers to squeeze the tabs together. They came right out. My 69 for whatever reason has a full set of metal retainers not plastic.
Steve
Bakersfield,CA
1969 monza coupe
110, 4speed
Bakersfield,CA
1969 monza coupe
110, 4speed
I should have added - slide the pliers between the clip and the lid to release.
Steve
Bakersfield,CA
1969 monza coupe
110, 4speed
Bakersfield,CA
1969 monza coupe
110, 4speed
