Page 1 of 1
Engine sound and smoking
Posted: Sat Dec 09, 2017 7:04 pm
by 62'Brier
Hi,
I have a Corvan with a recently (last summer) installed 110 overhauled engine. I have driven it quite a bit, from his shop in Santa Clara CA to Modesto where i live and around town for small trips.
He said there would be a break in period and to take it easy for about 500 miles then go for tune up.
I have been doing that. Changed a belt, kept the oil at good level.
One time I stepped on the gas and all of a sudden it was louder when I checked at home the muffler popped off? I've been driving it like that cause I like the aggressive sound.
Tonight I was driving it and it started making a different louder sound and a smell. Pulled over and checked the belt was fine. Then I decided since I didn't have my phone to start it and try driving it several miles home. Still made the sound but then I saw smoke. I'm now waiting for AAA to tow it home.
I've got a lot to learn.
Sent from my MediaPad T1 8.0 using
Corvair Forum mobile app
Re: Engine sound and smoking
Posted: Sat Dec 09, 2017 7:10 pm
by Jerry Whitt
What color is the smoke? From where was the smoke emitting?
Posted: Sat Dec 09, 2017 9:04 pm
by 66vairguy
What type of transmission?
If an automatic and the smoke is white --- could be leaking modulator valve.
Other than that I'd have an experienced Corvair person look at it.
Posted: Sat Dec 09, 2017 10:15 pm
by 64powerglide
Hey 66 he said in another post it was a 3 speed. Might be big trouble if it's exhaust smoke.
Posted: Sun Dec 10, 2017 8:49 am
by 66vairguy
64powerglide wrote: ↑Sat Dec 09, 2017 10:15 pm
Thanks 64 - He also mentioned the muffler fell off! The muffler just doesn't quiet things down, it routes fumes and heat away from under the vehicle. Not very safe driving a vehicle with no muffler - carbon monoxide poisoning comes to mind.
Posted: Sun Dec 10, 2017 5:28 pm
by miniman82
An open exhaust can also cause an engine to run leaner than it otherwise would, so if it was already sort of lean burned valves may be the result. Hope that’s not it, but I’ve seen it before.
Posted: Mon Dec 11, 2017 8:35 pm
by 62'Brier
Good thoughtful replies. The smoke was dark I think. The tow truck driver sniffed the oil from the dipstick and thought it smelled like gas.
Posted: Mon Dec 11, 2017 9:26 pm
by 64powerglide
That still doesn't tell us where the smoke was coming from.
Posted: Mon Dec 11, 2017 10:10 pm
by Jerry Whitt
Dark colored smoke, if coming from the exhaust, indicates excess fuel. The other sound you hear could be almost anything. This is where you are now the prime investigator and must use your vision and ears to help identify what the specifics are. Put the muffler back on the car and let know what you are seeing and hearing.
Posted: Tue Dec 12, 2017 8:13 pm
by 62'Brier
Thanks all you guys. The tow guy said it could be a ring. I don't know a whole lot about engines but am enjoying learning.
Another thing I didn't mention was it sounds normal at idle but when you hit throttle it has the louder sound.
I called my mechanic and he says he doesn't think it's anything too big but I imagine it will still require a tear down to get to it.
I'll post on here what comes of it when I get there and if it's resolved.
Posted: Wed Dec 13, 2017 1:03 am
by Jerry Whitt
A damaged ring does not make noise.
Posted: Sat Apr 21, 2018 9:15 am
by 62'Brier
Update from couple months ago: took her to MEL's and he checked it out. Had a cracked piston right where the noise was. Had to pay for that fix. I was the one driving around with no muffler. Put it back on.
Now I have electrical problem - it has always taken a little while when I turn the ignition to fire up. Well I was driving it in town stopped somewhere, went to leave and when I turned the ignition NOTHING. Lights wouldn't even turn on. I called AAA and a electric guy used his jump box and it started right up, faster than without the jumper box. Says the volts measured on battery was overcharging so he thinks generator.
Haven't done it yet, but Mel says to get it started again and then take a terminal cable off and if it dies then replace the generator/regulator. Is this how to diagnose?
Thanks, and looks like it's leaking oil now. Maybe because the exhaust was so close to the seals...
Sent from my iPad using
