John’s 65 sedan
Project65
Re: John’s 65 sedan
Post by Project65 »
Thanks 66vairguy. I was thinking some kind of undercoating would be the answer. I’m also thinking that in the remaining exposed areas of metal, I’ll coat with POR15 first, then the undercoating. Any additional touch-up and coverage will help protect and reduce road noise.
A few weeks back I ordered the vinyl stickers from Scott H for my headlight bezels. After applying and 4 light coats of KBS clear, they’re ready for install. The clear is designed to spray directly on bare metal. Polished aluminum. They look really nice. Much better than before. Thanks again Scott. A great product!
Today I installed the drivers side window weatherstripping channel. I backed the trim with 3M bedding and glazing compound. That applied pretty well. I attached it to the car with new screws. Clark’s doesn’t sell the screws, so I found some online from another seller. They’re the exact ones like the factory. They’re apparently the GM style from ‘64-‘77.
Polished bezels with Scott’s stickers and clear coat.
The factory style weatherstripping channel screws.
Channel installed on the driver’s side with new blow-out clips.
John
Project65
Re: John’s 65 sedan
Post by Project65 »
It’s been almost 2 weeks since my last post, but the reassembly continues. Longer update here.
Last week I coated the inside bottoms of the doors all around for rust prevention. First a coat of POR15, then a coat of rust reformer and sealer, followed by a layer of rubberized undercoating. The doors are now good inside and out.
I also installed the weatherstripping channel on the passenger’s side and the weatherstripping itself on both sides.
Then I installed a set of mirrors. Boy they really shine and look nice! :tu: I had to install the vent window on the passenger’s side as well as the driver’s seat to allow me to sit in the car behind the wheel and position the mirror on the passenger’s side exactly where I wanted it. I didn’t go with sheet metal screws. I picked up some stainless #10-24 screws and stainless nylon lock nuts and bolted them on. They’re good and solid for sure.
I also spent some time tweaking the doors a bit to get them a slightly better fit.
All of that was preparation for installing the windows that I rebuilt. What a really NOT fun job that was. Today I took a few hours off from work and tackled the install. I read from an old thread that white lithium grease seems to work, so I picked up a tub and lubed the rollers. After 6 hours of careful installation and adjusting, the windows are in on the driver’s side. What a chore to get all of the tracks and the weatherstripping to line up just right. :banghead: I’m sure that I’ll have a little bit of wind whistling when I roll down the road, but it’s as lined up as close to perfect as I could get. The fun of a 4-door hardtop I guess. :dontknow:
I haven’t installed the fuzzies just yet either.
Driver’s side glass in.  Looking more finished now.
Another view.
Another view.
John
gbullman
Re: John’s 65 sedan
Post by gbullman »
Amazing transformation. This car truly is a Phoenix!
Gary Bullman
66 Corsa Convertible
Project65
Re: John’s 65 sedan
Post by Project65 »
Thanks Gary! It is coming back from the 💀. I’m loving the transformation!
It’s been a few weeks since my last post, but progress continues.
The passenger side glass is in. I had to reset the front window glass in the channel forward a half-inch as well as realign the doors. :banghead: The glass now fits and the doors close much better. Still no fuzzies in just yet.
Then I’ve reinstalled the rear tunnel rails. After completely replacing the floor sections, the rails didn’t quite line up. :banghead: So after some shimming and welding, all lines up now. My long tunnel pan cover was junk, but the donor car pan was salvageable and after welding in three patches, I saved $118 from Clark’s. :tu:
Today I masked off the trunk and engine bay and did some prepping for finishing. For the trunk, some rust converter and sealer in the lower front corners, to protect. And epoxy primer. I’m going to apply some surface filler in the trunk for cosmetic appearance. It’s all solid and welded now, but just want to improve it a bit. Out back, I applied some rust converter and sealer as a base coat. Next, will be seam sealer.
Here’s a few photos.
Passenger side glass installed and doors aligned.
Trunk preparation for surface filler and finish painting.
Engine bay first base coat. And Rex’s tool!
Side view.
Side view.
Other side.
Other side.
John
cnicol
Re: John’s 65 sedan
Post by cnicol »
As a sedan fan, I just read your thread; wow! Amazing start to nearly finished. :tu:
Project65
Re: John’s 65 sedan
Post by Project65 »
It’s been a month since my last post and progress has been slower than desired. Shopping for a new car for my wife, and helping my son with him also getting a car, taxes, some travel for work, the holiday, etc. Somewhere in between all of that, there has been progress.
I’ve been trying to get the trunk finished, so I can proceed with the reassembly. After filling in and smoothing the surface imperfections from the welding seams, and applying seam sealer, then primer, today I was able to paint the trunk with the splatter paint. Rattle cans of the correct paint are non-existant, so I resulted to the quarts from Clark’s.
The rest of the car looks too nice for me to have a ratty and scarred trunk, so I took the time to make it look better. I’m glad I did.
I’m very satisfied with how it looks and more satisfied that the painting is done! Finally!!
After this dries, I’m thinking it’s time to begin the reassembly. Wiring, chrome, trim, lights, etc.
Passenger side
Passenger side
Driver side
Driver side
Whole view
Whole view
John
toms73novass
Re: John’s 65 sedan
Post by toms73novass »
Looks great, well worth the effort! :tu:
1962 700 Wagon
1963 Spyder convertable
1965 Monza
1967 UltraVan 211
Re: John’s 65 sedan
That trunk looks great.
Just a suggestion. If you haven't cleaned and lubed the trunk latch mechanism, then I suggest doing it. Just something that makes the car nicer everytime you open the trunk with the key.
I soak the door and trunk latches in solvent (gasoline is fine IF done outside). I follow that up with a light oil and then lube with the basic white lithium grease MIXED with STP oil additive as it keeps the white grease from drying out.
Dennis66
Re: John’s 65 sedan
Post by Dennis66 »
Slow progress is still progress. Glad to see an update. Dennis
County98
Re: John’s 65 sedan
Post by County98 »
I just got around to re-reviewing your thread. Awesome job man. Massive amount of work and I'm jealous of your paintjob, lol. Nicely done sir.
Cheers!
-Shayne
Lawton, OK
'66 Corsa work in progress
viewtopic.php?f=52&t=8079
Project65
Re: John’s 65 sedan
Post by Project65 »
Thanks guys!
It’s been a challenging spring thus far for me to keep steady progress, and to build on that from my last post, I’ve been traveling for the last 3 weeks; however, this weekend I’ve been home and was able to make more good progress.
During my travels, the paint in the trunk has fully dried and hardened. I really like how it turned out, and it seems that it will be durable.
This weekend I installed the headlight buckets. It was kind of a pain and took a few hours. :banghead: But after some work and drilling new holes, the buckets are in and sealed. I used stainless steel fasteners.
Today I worked on installing the front bumper and grill. I media blasted and painted my original bumper brackets, then reassembled and installed the bumper. Getting some more chrome on the car is a huge psychological boost for me at this point.
I’m moving towards getting all of the lights in so it will at least start looking more like a finished car from the outside.
(Glad to see you’re back at it Shayne!)
Bumper, chrome, and emblem installed.  Also the empty headlight buckets.  (The trunk key is in the lock)
Trunk view.  Looking to install the other trunk accessories soon.
John
County98
Re: John’s 65 sedan
Post by County98 »
Man, that trunk came out nice! Re-assembly is the fun part for me. Enjoy it buddy!
Are those the bowtie mirrors from clarks? I'm torn on using those or getting some mid-70's camaro junkyard mirrors. Someone previous already put holes in both doors.
Cheers!
-Shayne
Lawton, OK
Re: John’s 65 sedan
Yes it really gets visually satisfying when you start assembling all the trim onto the car. Looks great.
BTW - nothing wrong with taking a break when other things in life come up. Avoids project "burn out".
I had a few "parking" dings I worked out of my rear fenders. When I installed the engine compartment insulation from Clark's it covered that all up and I was amazed by how much quieter it made the car!!! It really works well.
It is brittle so you can't bend it too much or it well break/tear. Also put on a face mask and buy LONG rubber gloves or you hands and lower arms will have "fiberglass itch" for days. You don't need a lot of adheasive. Just a few spots to keep it from walking around.
I enjoy seeing the great progress you've made.
Re: John’s 65 sedan
County98 wrote: Sun Apr 28, 2024 9:45 pm Man, that trunk came out nice! Re-assembly is the fun part for me. Enjoy it buddy!
There are a few different offshore companies that make the mirrors (same on most Chevies of the era). Some have a habit of getting sloppy, others do not. I passed on the Clark's mirrors after folks posted the mirror head/ball gets sloppy (mirror won't stay in place). I bought mine from another GM parts vendor and they have been great! Some companies carry the OEM brand of GM trim that I've found to be a good quality - of course it costs more.
Project65
Re: John’s 65 sedan
Post by Project65 »
Yep. The side mirrors are the bow tie mirrors from Clark’s. When I had the car painted, all of the original holes were filled with weld. Originally, my car didn’t have a side mirror on the passenger side. The donor doors I used both previously had mirrors; however, the driver’s side was mounted way too far rearward. It looked bad.
I decided to add the passenger mirror for both safety and looks.
What I found out when installing both was the driver side door has an extra layer of internal steel to better support the mirror and screws. The passenger door didn’t have any extra internal reinforcement. I installed both mirror bases with stainless hardware and nylon lock nuts on the inside. I also had my son help me by positioning the passenger mirror on the door for both clearing the vent window frame and for visibility. I installed the driver’s seat for that reason. Once the passenger mirror was set, I mounted the driver’s side to match.
I do really like how the trunk came out. I’m glad I put in the extra effort. I included a couple of photos of the original trunk for humor . Rusted out badly.
Passenger first
Passenger first
Driver side to match
Before
Before
Before
Before
Before
Before
John
Re: John’s 65 sedan
The assembly manual only shows the drivers side mirror installation.
The 1966 Accessories Installation Manual isn't much help as it says to use the paper template, but turned over to drill holes in the passenger door. Not much help.
Like you, I found the drivers side factory mirror holes location didn't work to allow vent window to clear and not be blocked by the vent window post when viewed from the drivers seat. I did what you did and found a spot that worked. Nobody will notice it is not exactly the same as the drivers side.
I could find no mention about using a re-enforcement plate (like drivers side door is built with) for the passenger side. I made my own and used an expoxy to bond the plate to the inside door to keep water from getting behind the plate. Now passenger mirror is rock solid, no vibration driving down the road.
Here is an SCC article to change mirror to a wide angle mirror in passenger outside mirror (regular mirror view is too narrow for heavy traffic).
20230326 Wide angle passenger mirror upgrade.pdf
(1.04 MiB) Downloaded 6 times
