Silent Cam Gear
Re: Silent Cam Gear
My 140 cam gear has two set screws. I noticed them when I had the powerpack out for gaskets and seals. Unfortunately, I did not record any data on the cam or cam gear so I have no idea what's in the engine as I bought it this way. It does have a gentle lope to it.
Rory
Conway, SC
1966 Corsa
1963 Rampside - still trying to get it on the road
Conway, SC
1966 Corsa
Re: Silent Cam Gear
I'm still running the same 2304 cam & gear (GM, IIRC) I bought from Clarks 40 years ago. Low miles, cam still measured good when I tore down the engine last year.
Re: Silent Cam Gear
lost ONE IN MY 69' GOAT- AT 60K MILES-Dennis66 wrote: ↑Sun Mar 31, 2024 3:00 pm They call it silent because the car will be silent after it fails. I remember the old nylon faced gear son mouse motors (Chevy small block) back in the '70s. The nylon would fail and throw the timing chain. Always replaced them with a solid steel gear. Dennis
Re: Silent Cam Gear
Yeah, my kid brother rolled one in his '69 Kingswood wagon. 350k had it wound up tight. Bent 14 of the16 valves. We always replaced the nylon coated gears with a solid steel. Dennis
Re: Silent Cam Gear
Your cam's set screws are an advanced counter-measure that prevents the gear from slipping. This modification is usually reserved for high-performance or racing engines.
Is your cam gear all aluminum?
"Silent" cam gears were either an aluminum hub with nylon teeth or all-fiber construction. Neither of these composite gears are as durable as the proven all-aluminum gear.
