'62 Monza convertible "Ralphie"
Re: '62 Monza convertible "Ralphie"
It was inevitable. The gas tank had to come out. I mean the car had been in storage since 2005. While it seemed dry, it's been in humid Florida for the last few years. I had thought it seemed pretty clean, I had put a gallon of gas in it, and pumped it out through the outlet, and while that came out a little brownish at first, it was pretty clear. I borrowed an inspection camera from work this last week. There really wasn't much light down in there, but it was enough that what I saw made me realize I needed to clean the tank.
In spite of what the Youtube videos show, getting the tank out sucked. This one's even been out before, I could tell just by looking at the hose clamps on the fill tube. I wrestled and carefully pried and finally it came out enough that I could undo the clamps on the fill tube hose, which was dry and cracked. Imagine my surprise when I pulled it from under the car and there on the top front was written "Dennis". Almost like the scene from the original Star Wars "I've been waiting for you Obi-wan Kenobi". Fact is, before 2005 this car belonged to a guy named Dennis. He died while it was in the shop and when all the legal stuff cleared years later it was bought by a guy named... Dennis. He had health issues and the car went back up for sale to be purchased by ME - Dennis #3. The car has been through some kind of restoration in years past as many parts, including the heater control I removed last week have the VIN engraved on them. I'll be working to clean the tank this week and see if it needs a liner coat or just cleaning. Dennis
Update: Still working on cleaning the tank, been doing vinegar soak and rotating it. Will probably do a stone tumble this week. The Caswell liner kit arrived yesterday. I also finally made room to park it in my workshop yesterday. Hated to, but had to keep it outside and covered up over the last year. I kept two UV treated covers over the top, and a single "breathable" cover over the entire car. The Corvair takes up 2/3s of the workshop, but still leaves a little room at the workbench on the other end of the shop.
I also took it for another spin around the block (about two miles) on the little gas tank yesterday. Kind of light on the steering, pulls a little to the right when braking, and still getting used to the old 4 speed pattern after years of 5 speed driving with reverse on the opposite corner. DennisRe: '62 Monza convertible "Ralphie"
So cleaning the fuel tank continued. I had made a "tank rotisserie version 1" using a pair of split pipes to clamp on the side flanges. Didn't work too well. I came up with 2.0 using a couple of 2x4 sections with blocks screwed to them and boxed the whole thing in. The trunions can be swapped from the ends to the sides. This worked real good. I started with gravel. this got a lot of crud out (dried gasoline residue and rust). Yesterday, I switched to drywall screws, worked even better. I got a lot of powdery rust and funk out of it. I then did two vinegar baths, then two or three water rinses, then the hot water and Dawn dish soap. Then finally I let it dry, cooled it off in the shade, plugged the holes and sloshed about a quart of Lacquer thinner in prep for the Caswell sealer. I mixed up the sealer and poured it in and sloshed it all around. That's when I found the pinholes. Fortunately, Caswell is very good at sealing holes, and they cover this in their instructions. I will let it cure for several days while I have all the hoses and sender seal on order from Clark's. Then I will put a few gallons of gas in it and slosh to make sure before reinstalling it. Caswell is the best stuff I have ever used and is not affected even by ethanol. Definitely glad I decided to check and clean and seal the tank. Dennis
I've been done this road a few times. Now I just put in a new gas tank when I get an old car. In the long run it pays off - just me.
Over the years a few folks have posted that eventually the gas tank liner material breaks down and plugs up the system. Just what I have read.
Good luck.
Good luck.
If I'd known about he pinholes, I probably would have gone with a new tank up front. The cost of the Caswell kit was a good fraction of the cost of a tank. Hindsight. The Caswell stuff is good stuff though. I once used Red Kote on a motorcycle tank. It lasted a year or so (ethanol) and then I noticed the liner dripping down around the filler when gassing up one day. to make matters worse, the tank started rusting where the liner had separated. Had to clean it multiple times with Lacquer thinner to remove the Red Kote, then drywall screws and vinegar to remove the rust. The thorough cleaning and a Caswell treatment. Still strong several years later (and only non ethanol since, although Caswell is ethanol proof). Dennis
The snowball effect continues: I let the tank cure for a few days, then I thoroughly cleaned the outside and gave it a good coat of cold galvanized spray. I started thinking about the install and I thought "that gas fill area sure looks nasty". While the car had received a "re-spray" some time between 1962 and 2005, all the original paint that hadn't been sprayed has yellowed with age (doorjambs, under hood and trunk). Cleaned everything up, taped off, and sprayed. This led to also cleaning the gas fill tube (removing nasty undercoat) and painting it too. Now when all put back together it will look nice without having to be taken apart again. Dennis
Glad that's done. Dennis
Wow! It's been almost two months since I posted any progress. Been working on a lot of little things like sandblasting various tin and fittings and painting them. A major project I've been working on here and there was figuring out how to mount my fuel pump near the tank without drilling holes through the floor. Everybody seems to have these little round electric pumps that mount with a single loop and bolt. I took the advice here and ordered a Facet pump, it's square and mounts with two tabs. It would be easy to drill two holes through the floor, but I decided I didn't want extra holes and I wanted simple change out if needed, so I whipped up a bracket that has welded bolts (on top) and easily removable nuts underneath. Then I saw a post about fuel pump noise, so I modified it to have cushioned mounts that go into the side of the tunnel, the side body rail, and the front body rail. Installation required removing the tunnel cover so I didn't drill through any lines or wires. Took the cover off and paid a little closer attention to the clutch cable (slightly frayed at the bottom pulley). Time to change clutch cable (the car had come with a brand new cable in the trunk). The second breakdown I had on my first driver Corvair (1966 500) was a broken clutch cable (1973), that wasn't too bad. First gen clutch cable is a bear and my neck muscles are still sore a week later.
The joy continues: A week later (yesterday), I'm installing the fuel pump. When I go to hook up the hose, the nipple on the sender flange moves slightly . Had to take the sender out, solder the nipple, then put the sender back in. Had to make a tool to install the lock ring so I could push in to compress the O-ring while twisting the lock ring. Finally got all that done. Next project will be hooking up the wiring, which I had run some weeks back and installing a prime button. Dennis
I like it. I too have the square pump and mounted on foam but it hangs down too far. I may have to look into this mounting. Thanks for the pictures.
Colorado Springs
Colorado Springs
It has me worried now. The pump has an arrow pointing direction of flow. Following that, I have the end with the large Hex as outlet. The instructions seem to show the hex end as the inlet. Thinking about undoing the hoses and hooking to a battery to confirm.
Yes, I was concerned about sticking down myself, part of the reason I came up with this mount. Dennis
I think id go with the arrows over anything else.
Colorado Springs
Colorado Springs
Turns out I did have it installed correctly. That's behind me now. Because there is still electrical to hook up to the pump, and because part of that electrical (prime button) will be wiring behind the dash, it is time to focus on the Spyder dash install. First thing was to reset the Spyder odometer to match the mileage on my original speedo. I already had all the rest of the gauges cleaned and checked, but the speedo was still somewhat apart. I unscrewed the face, which allowed me enough room to remove the odometer drum and reset the numbers. Done. Next issue was that the Spyder dash doesn't have accommodations for the wiper switch or cigarette lighter, those are mounted in a separate pod that goes under the left side of the dash. I saw a pod on ebay, but it was over 70.00 plus shipping, so I decided to make my own. I cut a piece of 2'' angle steel, radiused the corners, welded and bent side pieces, drilled holes for the lighter and switch, and gave it a couple of coats of bedliner spray for texture and a top coat of satin black. I'm pretty happy with the results. Also note the two speed wiper switch, a facebook marketplace score. I'll sort out the two speed wiring and move forward with the installs.
Dennis
