Harmonic balancers are three-piece assemblies with a cast inner mount attached to the crankshaft, an outer steel ring, and the two are a press fit with a rubber insert that holds the two metal components together. As the harmonic balancer ages the press fit between the two metal components can begin to loosen, and the outer ring can slip. This could mean that the outer ring would no longer be in proper alignment with the center part, which is held in place on the crankshaft with a Woodruff key. With a solid crankshaft pulley the Woodruff key ensures proper positioning of the timing mark on the outer edge of the pulley. But with a faulty harmonic balancer the outer mark can slip, which can mean your timing mark may no longer be accurate.azdave wrote:...Harmonic balancer outer rings can slip and provide bad info. Distributors can have bad/stuck advance mechanisms...
The Corvair shop manual indicates that there should be a registration mark on the face of the harmonic balancer that indicates a proper relationship between the inner hub and outer ring. If the mark is there but the two parts are not in alignment, the harmonic balancer has slipped and is failing and must be replaced.
You can read more about harmonic balancer slippage at the following Corvair Center link...
http://corvaircenter.com/phorum/read.ph ... 740,494964
