Page 2 of 2
Re: My first attempt to build a 1965 corvair V8
Posted: Thu Oct 26, 2017 1:34 pm
by triumphcorvair
I wish I had your skills! :
Posted: Thu Oct 26, 2017 7:18 pm
by Trip
triumphcorvair wrote: ↑Thu Oct 26, 2017 1:34 pm
Me too!
Posted: Sat Oct 28, 2017 7:08 am
by toms73novass
I really like where the engine sits. The thing that has always turned me off on the crown/kelmark was how close the engine was to the front seats. It looks like yours will only be as far forward as the front of the rear seat bottom! I am watching your thread closely, this looks like what my next project might be, if all goes well with yours.
Posted: Sat Oct 28, 2017 8:33 pm
by Manny's corvair
Well today I went down to the metal shop but it was closed. So I have to wait till Monday to get more steel. Bummer!
After much consideration and forethought I decided to change up a bit my front motor mount. I fiqure 500 hp would crack my weld on a hard launch. So I decided to build a front crossmember with rubber mount to soften the force and vibrations. Back to the drawing board.
In the mean time I did some aluminum work to find a way to hide the engine. Still need to make some cuts and adjustments.
Posted: Tue Oct 31, 2017 11:51 pm
by Manny's corvair
I've been a little busy with my college work. So I decided to take an hour or so and make the new engine crossmember. I still have to do the oil pan clearance. I have to also keep in mind the cable to the original emergency brake which I want to keep.
Posted: Wed Nov 01, 2017 3:19 am
by toms73novass
Great work, keep on posting updates! I am watching taking notes. :D
Posted: Fri Nov 03, 2017 12:30 am
by Manny's corvair
The new finished crossmember
Need cleaning and paint
Posted: Fri Nov 03, 2017 3:28 am
by toms73novass
Question, Have you thought about putting a rubber/polyurethane bushing in the mount so that you don't get the engine vibrations into the chassis?
Posted: Fri Nov 03, 2017 8:20 am
by Manny's corvair
(toms73novass)
The engine has the polyurethane/rubber motor mount on it. The crossmember bolts up to that. I will take a photo of that.
Posted: Fri Nov 03, 2017 8:06 pm
by Manny's corvair
finished installing it and I am pretty happy with the results. I did not think It was going to come out this good. No expert but for a newbie welder with 30 minutes of youtube video instruction not bad......lol.
Posted: Fri Nov 03, 2017 8:25 pm
by Manny's corvair
Okay o decided to put in the roll cage and some aluminum work and an old seat I have to see the clearances and how much can I move the seat back. I'm 6 foot two so I'm tall I need the leg room. But it was perfect I even had to move the seat forward to work the pedals.
I know some folks are looking at engine placement. I just don't like the engines with crown or kelmark conversion being so far forward. I'm scared if the engine decided to loose a rod I won't be wearing it as a unicorn.
The engine may have to move forward or back but it won't be by much. I have to line up the drive shaft. I'm hoping it will go back.
Posted: Fri Nov 03, 2017 8:40 pm
by Manny's corvair
Some more pic
Posted: Sat Nov 04, 2017 7:50 am
by toms73novass
ahhh, I see what you have done there!
Posted: Thu Oct 18, 2018 7:28 pm
by Martys65corsa
Any chance you can send me details and measurements on your build? I'm looking at building a 65 also, Thanks
Posted: Fri Oct 19, 2018 9:46 am
by 65Ragtop
This is really nice. I'll be following with great interest.
