Where to buy rims?
Where to buy rims?
I'm getting ready to purchase some 15" rims for my LM. What are some of the places that you guys recommend I should shop. I'm thinking Summit and JEGS. Is one better than the other? What's your experience? Other options?
Re: Where to buy rims?
You should read about wheel offset on Bryan Blackwell's autocross pages: http://autoxer.skiblack.com/tires.html In my opinion it would be good to make an effort to get close to optimal offset/backspacing to avoid issues.
Wheels Vintique http://www.wheelvintiques.com/ can supply nice looking wheels with correct backspace.
Marty Scarr
Marty Scarr
I have bought wheels from both Summit and Jegs . Both were quick to deliver !
- davemotohead
15" tire selection is getting slim, you might think about 16-17" wheels for a better tire selection.
I have always ordered from Summit. But both are good. If I call by 1pm, my summit stuff is on my doorstep the next day. I am close to them though.
I have heard the 15's are getting tougher on the tires. I didn't know how well 16's would fit on early model?
For the early model is it a 4X4.50 bolt pattern? I am not seeing many "4 bolt pattern" for my early model......
Here are some informative links that should help you in fitting some larger tires and wheels to an EM Corvair...Sizing Corvair Wheels and Tires wrote:Interchange Information.
Since many folks want to know what to shop for online, at swap meets, junk yards, etc., here is some info which might be helpful.
Earlies have 4 lugs on a 4 1/2" (114.3mm) bolt circle. Other cars with that 4 on 4 1/2 pattern are:
Acura Legend '86 to '90
Chevy Nova, Chevy II '60 to '64
Chevy Sprint '85 to '87
Buick Special, Olds F-85 '61 to '63
Datsun/Nissan, most RWD models to '89
Dodge Colt '79 to '92
Ford Falcon, Mustang (6 cyl) '60 to '73
Ford Granada, Maverick '81 to '83
Hyundai all years
Infiniti G20 '91 - '96
Infiniti M30 '90 - '92
Mazda 323 '86 to '89
Mazda 626, RX7 '83 to '87
Mazda GLC '81 to '85
Mazda RX-7 GSL/SE '84 to '88
MGA, MGB, MGC all
Mitsubishi, most 4 lug all years
Nissan 240SX all 4 cyl
Nissan Altima '93 to '01
Olds - F-85 '61 to '63
Plymouth Arrow, Sapporo '79 to '88
Saab, all to '87
Toyota, most RWD except PU and MR2 up to '85
Triumph TR3 through TR6 all
Most info from a wheel swapping chart of mid 1989.
Thanks to Martin Scarr for this data. One thing to bear in mind is that the FWD cars listed here will have a lot of backspacing, so measure it before you buy.
http://www.the510realm.com/viewtopic.php?t=26740
http://www.tirerack.com/landing/Landing ... 09113818:s
bbodie52 wrote:Here are some informative links that should help you in fitting some larger tires and wheels to an EM Corvair...Sizing Corvair Wheels and Tires wrote:Interchange Information.
Hyundai all years
MGA, MGB, MGC all
Saab, all to '87
WOW, thats great info!! Thanks. I just saved that!
I would like to know where to get these wheels. I like these.
Dave makes a point. A fellow in our club gave up on 15" rims and went to 16" because he could not find new tires to fit.davemotohead wrote:15" tire selection is getting slim, you might think about 16-17" wheels for a better tire selection.
On my 66 I run 14" and was surprised the 205/70 front and 245/60 rears are still available for 14". A lot of muscle car folks still use the 14" sizes. Both these sizes are nearly the same circumference as the old 7:00X13 tire. The 205 works on a 6" or 7" wide rim. The 245 requires a 7" wide rim.
You might consider 14" since they give a good ride, but if you are into the "rubber band" tire look then 16 or 17" rims are the way to go.
On a LM with a wider tire you'll want a 4.5" backspace (you could go more, but may have interference problems).
Be aware that some of the disc brake conversions require a larger/deeper rim.
I had no problem finding 15" tires. There are still alot of choices, at least around here. The only thing a little tough is matching up different sizes for front & rear. I bought cheapie Fusion Touring tires, 205 60 15 & 225 60 15.
BF Goodrich Radial TA's are still a popular choice in 15" & will remain so because of all the musclecars. Rick Norris up the street from me put 205's & 235's TA's on his LM Vert. I do have to agree that 15"s will start drying up, but IMHO is not a concern right now.
I also seriously considered 16" 'cause they seem the best compromise on ride, but wheel avaliabilty is slim. I was concerned about the ride quality going to 17''s . The bigger you go on the wheel, the more sidewall you lose. The 17" are a big step from the original 13"
I have a nice set of early 14" Rally wheels for sale off my LM. I had no problem finding some 205 70 14 tires for them.
http://www.cragarwheelapplicationguide. ... and=Cragar
Part Number: 3204644
Part Description: 14x6 Series 320 Chrome
Bolt Pattern: 4x4.5
Offset: 0
Backspacing (In): 3 1/2"
Load Rating: 1400
Weight: 21
Cap Part Number: 29169-1
Don't get too excited about the above picture. They are Cragar S/S wheels designed for a golf car! Size 12x7 Chrome Cragar SS Wheel 3:4 Offset. As far as I can tell the Cragar S/S style wheel is no longer sold in a 4-lug style.
Five-lug version...
I actually like those cragars. I will save that part number for later. I still find quit a few 14 inch tire sizes near me. When I had my other older car. I never had an issue with the 14's. I would have liked 15's though.bbodie52 wrote:
Bolt Pattern: 4x4.5
Offset: 0
Load Rating: 1400
Weight: 21
Five-lug version...
Is 3 1/2 backspacing okay? According to the one link someone posted above for early models, It said stock for early models is 4 1/4. Would this 3 1/2 work okay?
I just bought 15" tires for the front of my car - there were many choices .
I went with the BF Goodrich G-Force Rival in a 205/50/15 . The rival is a high performance summer tire with a
wear rating of 200 .
I also bought 4 new racing tires in 225/45/15 . They are track only tires with a 40 wear rating .
I'm not an Early guy but I think you would be fine . My late model has 15x6 front wheels with 3 3/8 BS and 205/50 tires and even spacers because of my disk brakes .Is 3 1/2 backspacing okay? According to the one link someone posted above for early models, It said stock for early models is 4 1/4. Would this 3 1/2 work okay?
Oh okay. I realized after I posted the less backspacing, the wheel is pushed outward. I was thinking the opposite, and of it rubbing the inner well. My brain got confused....UNSAFE wrote:I'm not an Early guy but I think you would be fine . My late model has 15x6 front wheels with 3 3/8 BS and 205/50 tires and even spacers because of my disk brakes .Is 3 1/2 backspacing okay? According to the one link someone posted above for early models, It said stock for early models is 4 1/4. Would this 3 1/2 work okay?
I looked on summit. I don't see many 15 inch for my early 4 lug. But I was looking in a hurry.
this may be a little after the fact. i bought mine from speedway in nebraska. brand new rallye wheels for $50 bucks each. you cant buy used ones for that. they look great and i bought 15s but maybe should have gone to 16s as tires are getting harder to find.
