Newbie,
Got a question what is the difference from the 728 smog & no smog 140 heads?
How do I tell which is which & can the difference be bridged?
Thanks
728 smog/ no smog heads
Re: 728 smog/ no smog heads
The smog heads will have a concave look on the inside combustion area lowering the combustion ratio.
Jerry
Jerry
Forgot to mention that information on Corvair heads and much more Corvair repair information can be had In the CORSA tech Guide vols. 1&2. You can purchase one from The CORSA website corvair.org is you are a CORSA member. Or sending a check for $45.00 made out to CORSA to Jerry Brown 4049 Liberty Church Rd. Manning SC, 29102. I can send you a CORSA Merchandise order form and you can use that to order also. I just forward the check to CORSA. Shipping is included in the price of the book.
Jerry Brown
Jerry Brown
Can you kindly post a pic of the two chambers?
See your other post - THERE WERE NO 149 SMOG HEADS - combustion chambers all the same, other differences, but chambers are all the same for 140HP heads.
Thanks for the reply's I'm going to get the engine.
