Powerglide
Powerglide
Can I put a valve body from a late tranny on an early to Handel higher horsepower output engines. This is on my rampside and I would like to put a higher performance engine in it than the 80 horse
Re: Powerglide
P.S. the reason I ask is the e clip broke in my valve body, so I’m in there already. I also can’t find the parts of the clip. It drove fine but would all of a sudden drop out of high all by it self. Then I would have to shift down and back up again and I would be cruising til it shifted down again.
Re: Powerglide
LOL, you never find the parts of the E-clip. They just seem to disappear!
As far as I know you should be able to put a newer valve body on for higher clutch pack pressures. If you are in the know, you can just change out the springs also,
With that, many people just put better engines in with no issues on early PG trans and no issues.
Ken Hand
248 613 8586
vairmech@aol.com
Corsa Past President
Corvanatics Vice Prez
Chair 2007 Detroit Convention
248 613 8586
vairmech@aol.com
- davemotohead
Re: Powerglide
There are more differences than just the valve body, some of the valves and passageways in the PG housing are different as well, You would be better off rebuilding your stock EM trans or upgrading to a complete LM PG trans, I would advise against mixing LM and EM parts.
Re: Powerglide
On the Corvanatics site there is a great write up from Bob Ballew (RIP) about all things PG including how to upgrade the early ones to the higher late pressures. I printed it off and put it in a folder for quick reference.
- Frank DuVal
Re: Powerglide
I can no longer find Bob Ballew on the Corvanatics website. But it is there! Why it is hidden I do not know. If I didn't Google Bob's name and Powerglide I would not have found it.
https://www.corvair.org/chapters/corvan ... ld_man.pdf
Hey look, blue background!
Re: Powerglide
I read Bob Ballew, Art Eller and I believe a third writing before I did my Powerglide. The end 'take away' as mentioned in the quote above is there were other differences beyond just the valve body. That said the trans was an early and by all indications had a late valve body (orange strip???). The car never ran so I had no idea how it worked. Thankfully I had two early transmissions to work with and fortunately it seemed what was was bad in one was good in the other. In the end I have a low power 80HP engine and figured that the early valve body was sufficient and used that.davemotohead wrote: ↑Mon Apr 08, 2024 7:41 am There are more differences than just the valve body, some of the valves and passageways in the PG housing are different as well, You would be better off rebuilding your stock EM trans or upgrading to a complete LM PG trans, I would advise against mixing LM and EM parts.
Re: Powerglide
Well, I read Bob Ballews articles and I’m going to go for it. Worse case I would put the original parts back in. Thanks for the help.
Also the ford is one I painted for my brother next to my wife’s spyder
