Question on ignition timing marks
All,
I have a 1966 corsa 140 4 speed. According to the tuning specs the timing should be set a 18 degrees... but the timing marks on the car only go to 16 degrees. What do you do guess ? I currently see it flashing a bit past the 16 mark... but it kind of silly to require 18 on a 16 gauge...
Jeff M. in Phoenix, AZ
1966 Corsa 140 4-speed
Re: Question on ignition timing marks
The timing mark 16 is above a short mark. The next full line is the 18 mark.
but there is no 18 on the scale... it's stops at 16..
The scale starts at 0, then 4, 8, 12, 16, then a smaller space of 2 degrees which then is 18
Some illustrations may be helpful. Although the shop manual distributor specifications state 18 degrees BTDC, the tune-up chart from the same manual specifies a range of 16°–20°.
Here is a close up of the standard timing scale casting. A small mark can be see to the right of the 16° mark...
I wonder how many different timing blocks GM made, here is my 64 110.
Thanks All...
I can't see the end mark that Brad mentioned (52 year old car) but I guessed and retarded to where I though where 18 degrees would be and using my ear, she perked right up and ran really smooth... all the pinging under load is gone now... purrrrrrrr......
Thanks again... Corvair folks are so cool...
Best timing for these cars in most cases is advanced as far as possible with no ping under any driving condition. There are exceptions as some engines can be over advanced beyond good operation and still won't ping:)
