what test equipment is required for older cars without computers
Other than dwell meter and timing light, what else do I need?
Re: what test equipment is required for older cars without computers
You technically don't even need a dwell gauge. You could adjust points with a feeler gauge.
You still need a timing light for modern vehicles too. So really there arent many of any specific tools needed for old cars.
-Steve
The dwell tachometer and timing light are the most common items thought of when working with an older engine in a classic car. As previously mentioned, however, there are ways to work around the lack of these tools. Adjusting the ignition points gap with a flat feeler gauge is a substitute for having a dwell tachometer. Setting the dwell with an electronic instrument is more accurate, however. The tachometer portion is needed to measure idle speeds and possibly to perform other tests where engine speed measurement is needed. It is possible to static-time your ignition system with a strip of paper placed between the ignition points. The engine timing mark can be manually positioned to the desired setting on the crankshaft pulley, and the distributor can be slowly rotated until the points just start to open and release the strip of paper. The distributor is then tightened and the mechanic has established an initial static timing setting. Of course, having a timing light makes things much easier, improves accuracy, and permits visual confirmation that the centrifugal advance is functioning. A vacuum gauge can be used for carburetor synchronization and other carburetor tests, and most vacuum gauges also double as a pressure gauge for measuring fuel pump output pressure. A UniSyn gauge, as shown below, measures airflow through each carburetor throat, and is an accurate way for synchronizing multiple carburetors at idle speeds and at partial throttle. A multimeter is a useful tool for troubleshooting and diagnosing electrical and charging system problems.
Many ignition systems in Corvairs have been upgraded by fitting an electronic ignition system to the distributor. These electronic ignition systems eliminate ignition points and condenser, which makes engine tuning somewhat easier and eliminates the need to periodically replace worn ignition points. The breakerless ignition system utilizes an optical or magnetic trigger to control the ignition coil. The system eliminates the need for a dwell meter or flat feeler gauge for ignition points adjustments. (A wire-type feeler gauge is needed for adjusting spark plug gaps). The tachometer portion of a dwell-tachometer, however, is still useful.
Learning to work with the two Rochester primary carburetors on the Corvair really isn't all that difficult. But you should take the time to review the shop manuals and other attached manuals to get a better feel for what you are trying to accomplish. It is important to perform tuning steps in the right sequence, as outlined in the shop manuals and in the video below. Many of the tuning steps can impact the results found in other steps. There is a logical progression in tuning a Corvair engine, and skipping around or tuning components in a random order can only serve to confuse the outcome. The Delco Rochester service manual that I have attached is a good supplement to the Corvair shop manual. About half of the manual is dedicated to explaining the various subsystems and components of the Rochester HV carburetor. To some extent these carburetors perform as you would expect a computer-controlled fuel injection system and ignition system to operate — but they were designed at a time when computer-controlled systems that were designed to respond to sensor input throughout the car would only have been a dream. The various carburetor and ignition subsystems respond to engine temperature, engine speed, airflow and vacuum changes, etc. much like a modern engine — but without all of the sophisticated electronics and sensors. Engineers were attempting to accomplish the things we do now, but with much less sophistication — but still making changes as engine speed, throttle position, engine vacuum, and fluid and air flow characteristics varied. If you take the time to read through the Delco Rochester manual, you might come to understand how the choke system functions, what an accelerator pump does and why it exists, and how the distributor is designed to adjust timing at low engine speeds and at higher engine speeds using both a vacuum advance and a centrifugal advance to provide the correct timing at various engine speeds and load settings. A good understanding of how these systems work and what they are supposed to do can be a great help when tuning and troubleshooting your engine.
The links, videos, and attachments below should help you to understand how to work with a dual carburetor engine. Try not to be intimidated by two physically separated carburetors. They really function very much like a single two-barrel carburetor, but are physically separated from each other out of necessity due to the layout of the flat air cooled engine with cylinders opposed to each other. The Corvair engine layout is in many ways similar to many motorcycle engine configurations. It usually takes an experienced automobile mechanic a little adjustment time to get used to the way things are done on a motorcycle. The aluminum, air cooled flat six Corvair engine often is seen as a challenge to an automobile mechanic, who is not used to the "strange configuration" found in a Corvair.
viewtopic.php?f=55&t=13170&p=90875#p90875
The entire shop manual and many other Corvair technical references can be downloaded at no cost using the following link...
viewtopic.php?f=225&t=6007
bbodie52 wrote:The Uni-Syn Carburetor Balancing Instrument is a tool that I remember as far back as the 1950s and 1960s. It was designed for use in multi-carburetor automobiles, motorcycles, etc. that were initially common in European vehicles, but were later found in American vehicles like the Corvair.flat6_musik wrote:...I bought a Uni-Syn and only used it once. It seemed to me that at idle, there was barely enough air flow to raise the ball. It pissed me off and I put it away...
The Uni-Syn is an airflow gauge that must be calibrated to match the specific engine airflow moving through the carburetor throat. The flow control in the center of the Uni-Syn is mounted on a threaded pin. Rotating the flow control raises or lowers it, which increases/decreases the air gap, which impacts the air velocity passing the oriface that allows some airflow to pass through the gauge. With the Uni-Syn held firmly on the carburetor intake with the engine idling, the flow control is adjusted so that the plastic float is approximately centered in the glass sight tube. Once calibrated, the Uni-Syn can be moved back and forth between the two primary carburetors to compare airflow at idle. The goal is to play with the idle speed screws to get an even airflow level that matches between both carburetors, and at the same time produces the desired idle speed. Before fine-tuning this idle balance with a Uni-Syn, the ignition system, idle speed and idle mixture should have been adjusted following the standard procedures as described in the factory shop manual. The balancing step with the Uni-Syn gauge is added at the end of the tuning procedure to measure actual airflow though both carburetors at idle, and balancing that airflow using the airflow meter as a measuring tool, rather than simply relying on a physical balanced "calibration" using a strip of paper to detect initial contact between the idle speed adjustment screws and the carburetor linkage, followed by counting the screw turns needed to obtain the desired idle speed (and ensuring that the same number of screw turns are applied to each screw). That procedure achieves a fairly close initial setup. The use of the Uni-Syn airflow gauge as a final step ensures balance between the two carburetors by measuring actual airflow.
Once the balanced idle airflow and desired idle speed have been achieved, a similar procedure can be used to synchronize the airflow when the carburetors are held open at a faster engine speed by the throttle linkage. Again, the shop manual procedure can be used to set the initial mechanical balance between the two sides of the throttle linkage. The linkage segment connecting the accelerator pedal to the cross-linkage between the two carburetors is temporarily disconnected, and a turnbuckle is temporarily attached to hold the throttle opened against the pull of the throttle return spring.
The turnbuckle can be adjusted to hold the throttle open at approximately 1500 RPM. The Uni-Syn center flow control is readjusted to re-calibrate the float to a position somewhere in the center travel of the sight tube, based on the increased airflow through the carburetors at the higher steady RPM maintained by the turnbuckle arrangement. As with the idle synchronization procedure, the re-calibrated Uni-Syn is used to measure the airflow moving through the two carburetors. The goal is to fine-tune the threaded portion of the carburetor actuation linkage so that the same airflow reading is attained on each carburetor, but this time with the throttles held open by a pull on the throttle linkage, instead of by the setting of the idle speed screws. When the airflow has been balanced using the throttle linkage adjustment, the balancing procedure has been completed and the normal accelerator pedal throttle linkage can be reconnected.
TIPS & CLARIFICATION...
Once the carburetors are drawing equally at idle, hold an engine speed: at about 1500 RPM. This checks that the mechanical linkage is pulling equally. You'll need to open up the Uni-Syn center wheel to draw more air and bring the bead down in the tube. If both carburetors are within a bead's thickness of each other, that's good. If one is definitely off from the other, the higher flow carburetor's linkage is being pulled more than the other. You'll need to figure out why that's happening mechanically to rectify it.
- (2.92 MiB) Downloaded 18 times
- (8.87 MiB) Downloaded 20 times
- 1965 Corvair Chassis Shop Manual - SECTION 6Y - ENGINE ELECTRICAL.pdf
- (8.51 MiB) Downloaded 20 times
- (1.79 MiB) Downloaded 21 times
That entire reply should be a sticky. Amazing information there.
-Steve
- toms73novass
Brad your responses are amazing! I am always in awe of how much information you pack into a response.
1962 700 Wagon
1963 Spyder convertable
1965 Monza
1967 UltraVan 211
1965 Monza
1967 UltraVan 211
Brad is the info man! [emoji106] [emoji106]
Ed Stevenson
Ed Stevenson
