Crazy extra oil cooler setup
Today I found the craziest attempt at additional oil cooling I have ever seen. Systems drew oil from center bottom of oil pan via 2 electric pumps and many feet of rubber hose through 4 12"x12" oil coolers mounted under the floor and returned the oil to the valve covers via tubes welded into the cover with a few holes "squirting" oil toward the rockers. See photos for a good laugh.
Re: Crazy extra oil cooler setup
One good speed bump and it would become another "Valdez" fiasco.
LOL a likely superfund cleanup site indeed.
- MtnVairMike
Bubba should stick to rockets and lawnmowers. Geez.
Mike
Mike
Well, you have to give him an "A" for a LOT of effort!
I have to say- I do LIKE your car LIFT!
Craziest "Rube Goldberg" contraption I've ever seen!
Is any of that even rated for oil use? Lol those look like fuel pumps and heater hose.
-Steve
Probably not , best I could determine it was fuel pumps and fuel or trans fluid rated hoses. It was leaking all over but then there was quite a few connections.
terribleted wrote:Probably not , best I could determine it was fuel pumps and fuel or trans fluid rated hoses. It was leaking all over but then there was quite a few connections.
lol I wonder why this seemed necessary. Also I wonder is it was effective at all. I drive my 80hp vair with partially bad engine tin seals in 90 degree weather and it stays within operating temperature.
-Steve
My thoughts exactly. With the coolers all mounted flat under the floor pans and therefore not really getting any airflow through them I doubt this system did much except increase the oil capacity, make leaks, and make it impossible to do a complete oil change. This is why it all went in the trash, but you know the guy who did this was likely a rocket scientist:)lostboy wrote: ↑Fri Mar 24, 2017 10:27 amterribleted wrote:Probably not , best I could determine it was fuel pumps and fuel or trans fluid rated hoses. It was leaking all over but then there was quite a few connections.
A rocket scientist? Only if he worked for Morton-Thiokol (the infamous space shuttle solid fuel booster builder...)
