Corvair Security
Corvair Security
I wanted to get some inexpensive ideas to protect my car. I was thinking of a kill switch off the negative side of the coil. I would also like to lock the engine lid.
Jeff
Jeff
1965 140 Corsa
1965 Corsa Convertible
1966 Crown V8 383 435hp
1986 Buick GN V6 600hp
Re: Corvair Security
A Remington 870 should do the trick.gnrand wrote:I wanted to get some inexpensive ideas to protect my car. I was thinking of a kill switch off the negative side of the coil. I would also like to lock the engine lid.
Jeff
-Steve
Clarks sells an engine lid lock.gnrand wrote:I wanted to get some inexpensive ideas to protect my car. I was thinking of a kill switch off the negative side of the coil. I would also like to lock the engine lid.
Jeff
SCfromCanada wrote:Clarks sells an engine lid lock.gnrand wrote:I wanted to get some inexpensive ideas to protect my car. I was thinking of a kill switch off the negative side of the coil. I would also like to lock the engine lid.
Jeff
Thank you! I never thought of looking at Clarks for that lock.
1965 140 Corsa
I have hidden a kill switch in the rear cowl area cutting the ignition feed to the engine compartment in the rear of the main body harness. A couple fairly knowledgeable Corvair guys spent a few hours trying to figure out why no ignition power. Then some one recalled that the car might have a kill switch....even then they did not find it (they would have had they had a lift I think). I told them the location when they called me after someone suggested that I had installed it.
Mine has an electric fuel pump kill switch. Only problem, have to remember when it was turned off!!!!!
Thank you for the replies. Since these cars are so easy to hot wire; I want to be pro active protecting them.
Jeff
Jeff
1965 140 Corsa
If I tell you exactly what I've done it wouldn't be a secret.
The best protection is stopping the car from being able to roll so think of hidden ways to block the E-brake from being released.
Next is to disable the fuel system. If you have an electric fuel pump you know what to do but hide your work well. With a mechanical fuel pump, hide a manual shut-off valve somewhere in the main line. They will only drive a short distance until the fuel bowls are empty if you can kill the fuel supply.
Killing the ignition is easily bypassed by a serious thief but it does thwart the rookies. In one of the old Corsa Tech Topics there is article about drilling a small hole in the LM engine cover latch levers so that a small pin or cut off nail can be inserted to block the lever from moving fully. Most Corvair owners I share that with never see the pin there even when they look. My dad used that trick back in the 70's when kids were stealing his batteries.
Corvair Security
All kidding aside, if someone wants to steal from you, they will. It sucks, but it's a fact. Best thing might be to put a boot on it like the police use or park it inside. I have thought seriously about a removable steering wheel like the Honda kids use, but I like my original steering wheel.
I should add, local to me are a lot of Hondas that have expensive engine swaps and whatnot. They tell me that the thieves themselves say the removable steering wheel is the best way, second is a boot.
-Steve
- MtnVairMike
Clutch, most can't drive them these days.
Mike
Mike
HAVE. A GOOD. FRIEND WITH A CORSA.HIS DAUGHTER WORKED AT MAGIC MOUNTAIN IN SANTA CLARITA AND DROVE THE CAR EVERYDAY. SHE WOULD PUT A LOCKABLE CAR COVER ON IT BEFORE GOING IN. ONE DAY SHE CAME. OUT TO FIND THE CAR COVER CUT BUT. THE CAR WAS STILL THEIR WITH A NOTE. SAYING NEXT. TIME ONLY. THING SAVED IT WAS THE REMOVABLE STERLING WHEEL SHE PUT IN THE TRUNK LOL JOE
Sent from my IdeaTabS2109A-F using Corvair Forum mobile app
1962 rampside #3957
Yeah that's what the Honda guys do.joe moore wrote:HAVE. A GOOD. FRIEND WITH A CORSA.HIS DAUGHTER WORKED AT MAGIC MOUNTAIN IN SANTA CLARITA AND DROVE THE CAR EVERYDAY. SHE WOULD PUT A LOCKABLE CAR COVER ON IT BEFORE GOING IN. ONE DAY SHE CAME. OUT TO FIND THE CAR COVER CUT BUT. THE CAR WAS STILL THEIR WITH A NOTE. SAYING NEXT. TIME ONLY. THING SAVED IT WAS THE REMOVABLE STERLING WHEEL SHE PUT IN THE TRUNK LOL JOE
-Steve
Yes, but most times they will move on to an easier target if you just do a few simple things to slow them down. If someone figures out how to get my Corvair started they still won't be able to get it to roll.lostboy wrote:All kidding aside, if someone wants to steal from you, they will.
Overall, I worry more about someone stealing my 87 B2000 pickup than I do my Corvairs.
Lol agreed.
-Steve
Like we say in the IT world. Security is an illusion. All you can do is make it not worth the efforts involved. but a determined criminal WILL always find a way.
CORSA Member #034095
1965 140 Corsa
