Knocking
eForce
Re: Knocking
Unread post by eForce » Tue Jul 26, 2016 3:38 pm
I found my knock!
can't get pic to work...try this
https://1drv.ms/i/s!Al5viGJMAfhzg1KUq4-BBulc_rd3
Re: Knocking
Unread post by cad-kid » Tue Jul 26, 2016 8:06 pm
Here you go-
CORSA Member#031129
xrotaryguy
Re: Knocking
Unread post by xrotaryguy » Tue Jul 26, 2016 8:14 pm
Haha, suddenly it's pretty straight forward.
Sent from my SM-G900V using Corvair Forum mobile app
eForce
Re: Knocking
Unread post by eForce » Wed Jul 27, 2016 7:44 am
now....is that the valve guide or the actual bore?
Re: Knocking
Unread post by cad-kid » Wed Jul 27, 2016 10:36 am
eForce wrote:now....is that the valve guide or the actual bore?
Valve guide based on my limited knowledge.
CORSA Member#031129
Steve62
Location: Altadena, California (Just north of Pasadena)
Re: Knocking
Unread post by Steve62 » Wed Jul 27, 2016 1:00 pm
Yup...valve guide. You'll need to pull the head, and might as well do both sides. Parts are cheap!
Could be better, could be worse...could be riding in a hearse!
toytron
Re: Knocking
Unread post by toytron » Wed Jul 27, 2016 7:26 pm
Steve is correct. Valve guide. Do both heads.
Sent from my SM-N910V using Corvair Forum mobile app
Scott V
Re: Knocking
Unread post by Scott V » Wed Jul 27, 2016 8:23 pm
Steve62 wrote:Yup...valve guide. You'll need to pull the head, and might as well do both sides. Parts are cheap!
parts are cheap....its the labor to do it right that adds up.
-Scott V.
Re: Knocking
Unread post by bbodie52 » Thu Jul 28, 2016 4:12 am
eForce
Re: Knocking
Unread post by eForce » Thu Jul 28, 2016 1:28 pm
oh indeed. I already have the heads off and my shopping cart loaded at california corvairs BUT...... I've got a line on a motor and tranny for $250. Rather than doing any machining, I thought I would pick that up and start with those heads. OR just use that whole motor since its together. Decisions decisions.
I questioned the bore because I know the valve guides are brass and these are magnetic so not brass. hmmmmm.
Also, one pushrod is mangled, there are 2 different kinds of lifters in each bank. Somebody was in there and didn't know what they were doing. Caused a cascade malfunction.
Steve62
Re: Knocking
Unread post by Steve62 » Sat Jul 30, 2016 9:11 pm
There are too many people in this world who should never be allowed near a tool! I tore down an engine last year with a missing top piston ring, mis-matched lifters and push rods, badly bent push rod tubes, and gasket sealer everywhere. Early cylinders, pistons and rods, late cam, early crank, late case, and two very different heads - one side turbo, the other, not sure...haven't looked it up, but non-turbo. The poor engine was in the process of self-destruction! But hey, it was cheap, and the case was good!
xrotaryguy
Re: Knocking
Unread post by xrotaryguy » Wed Aug 03, 2016 7:10 am
My favorite was a "set" of cases where the two halves came from different engines. The main bearing diameters were noticeably different just by fingering the transition.
