Slight Change in Engine Speed
Pathfinder
Post by Pathfinder »
I'm starting to detect an occasional slight change in engine speed after shifting gears. Revs up a smidge then settles in, but not every time. Seems to get better as the cars warms, but truthfully I haven't driven the car much or for any substantial length of time in a while. Clutch?
'69 140/4 Vert, Dusk Blue / White Top
'14 Durango LTD
cnicol
Re: Slight Change in Engine Speed
Post by cnicol »
If it gets worse in higher gears (3rd 4th), slipping clutch is likely.
funvairs
Post by funvairs »
Up shift? Down shift? All gears? Engine load, light, moderate, heavy?
Clear the area around the car. Block the wheels, set the E brake, start the engine, give it some throttle and let the clutch out slowly in all the gears. What happens?
Chris Brown
Member
CORSA
Check out your clutch cable, linkage (for binding issues) and especially the pedal free play. Gotta have your required free play.
Pathfinder
Thanks for everyone's comments. I usually add Stabil 360 at every gas up but got lazy the last 2 times. I added an oz. this morning and after about 2 hours of running errands around town she seemed back to her smooth self. I'll run it more this week and see how it goes...
'14 Durango LTD
