As it read , the carbs are backfiring like they are lean . These are 140 carbs I got from M. Nall that where supposedly modded by Unsafe . I was warned that they might be a little rich , but they act like the opposite . Secondaries are not hooked up . I ent to the car wash and noticed that the vac. adv. is fluctuating with the rpm of the motor . The motor runs good and does not miss except for the popping back , it`s usually under acceleration , it cruises at a constant speed smoothly .
Is it a burnt valvle ? It seems to do it on both sides , maybe the valves are too tight . I have to run this afternoon but I`m going to run a comp. test tonight .
Thanks , Dan
Carbs popping , Vac adv. fluctuating
Re: Carbs popping , Vac adv. fluctuating
forgot the notify me checkbox...
Just a thought. Are you sure the secondary are fully closed (would make things lean). Timing/ignition can cause popping back as well.
