Grease caracteristics and uses
Do you know what these symbols on a tube or tub or grease stand for?
Poll ended at Tue Aug 05, 2014 5:10 am
1
50%
1
50%
Total votes: 2
Richard1
Post by Richard1 »
There are different purposes for different types of grease.
Without looking them up, do you know what these symbols certify?
Richard1
Re: Grease caracteristics and uses
Post by Richard1 »
Don't be afraid to answer. It is anonymous.
I have a feeling it is a little known secret that would need addressing.
66Monza140
Post by 66Monza140 »
Top: chassis grease
Bottom: Bearing grease - higher Timken value :clap:
Case R.
1966 Monza 140 coupe
Western Champlain Valley, Vermont
Richard1
Post by Richard1 »
I take if from no one answering that this is a good thing to clear up. Grease is categorized for automotive use by these symbols.
Chassis grease starts with an L. LA was once the standard, but was then improved to LB. So any grease for chassis, steering, etc. should have the LB symbol on the container.
Chassis grease does not protect ball bearings well, and will generally melt in wheel bearings, especially with disc brakes, so the G category was developed. At first it was GA, and maybe a GA would work with non disc brakes. Then along came GB, and currently GC. Any grease with GC on it will work well on wheel bearings with disc brakes.
Most GC greases will also work well on chassis/steering components, so they will be labeled LB-GC, covering both categories.
Of course there are different qualities within a category, with synthetics lasting longer in sealed applications, ans some greases offering protection at higher levels than others, but any grease with the LB-GC on it will work as long as any previous grease is cleaned out. In general, mixing types of grease (different thickeners) will cause it to turn runny separate like cottage cheese.
Good stuff as usual Richard. Good post :tu:
County98
Post by County98 »
Yup, thanks for the info. I was just trying to learn what to use the other day. Now I'll just go get some LB-GC Synthetic and use it on everything!
Cheers!
-Shayne
Lawton, OK
'66 Corsa work in progress
viewtopic.php?f=52&t=8079
