bHere are a few pictures for entertainment value!
My first natural-aspirated to turbocharged conversion was built around a Chevy 2.8 and a Rajay E-flow turbo. I got good service out of the system until a piece of a broken drill bit got in the turbo and ruined the compressor wheel. As we're all painfully aware, Rajay are out of production and parts are hard to find. Finally after several years, I found a new compressor wheel on eBay.
The broken turbo:
The turbine shaft has a small wipe of aluminum from the old impeller. That easily came off. The bearing surface looks like new, in spite of the fact that I drove the car for YEARS with this turbo!
Center housing all cleaned up.
Bearing about to go in the housing.
Bearing is in!
About to put the thrust bearing washer on the bearing.
Seal plate going on:
Completed assembly:
Flip over, and ready for turbine shaft.
Install the spring and heat sheild.
Turbine shaft is in! Lubed it with clean engine oil.
Now the spacers for the compressor impeller.
Impeller, washer and nut installed! New part looks so good in there!
The housing has numerous raised gouges from the debris in the turbo. They need to be knocked down before the housing is placed over the new impeller.
A few licks with a brake hone and they are smoothed down. There are some low spots but no raised burrs.
Insulation ring on the center housing where the turbine housing sits.
Completed turbo!
So that's the parts inside a Rajay E-flow turbo!
David
Rajay e-flow turbocharger repair pictures....
Re: Rajay e-flow turbocharger repair pictures....
I wrote an in-depth guide, if you care to have a look: http://miniman82.4t.com/car%20stuff/raj ... rimer1.pdf
- TikiRalf
Cool to see the turbo parts all together, me like it :-)
maybe in the future hihihi, keep on working on the turbo !!!
