gear stick jammed
gear stick jammed
my 1962 spyder is jammed in first gear
Re: gear stick jammed
Hopefully if is something not inside the gearbox. Was this a sudden issue or was it slowly getting hard to shift?
Get under the car where the front of the transmission can be reached. Inspect that coupler that connects the shift tube to the transmission input shaft. You might find a broken retainer pin or trashed coupler. If you disconnect the coupler you can check that the shifter is not jammed up underneath where it connects to shift tube. That shift tube should move forward- aft and rotate
Use a Phillips screwdriver that fits into the hole at transmission shaft and rotate it side to side and try to move it front to back in an H pattern as if shifting gears. Others will add more ideas.
Ken
'62 Spyder. '63 Monza.
More than likely the shifter was not adjusted properly and the lower ball popped out of the socket.
Unless you are real lucky and able to get the ball to pop back in you will have to remove the tunnel pan and manually put the ball back in. Also be prepared to replace the front shifter bushing and/or the bracket.
Ken Hand
248 613 8586
vairmech@aol.com
Corsa Past President
Corvanatics Vice Prez
Chair 2007 Detroit Convention
248 613 8586
vairmech@aol.com
I have a couple where the shift shaft coming out of the transmission is locked up. I haven't taken them apart to see what is wrong yet. I'm sure it isn't good.
