engine no start
engine no start
I have a 65 Monza 110 I drove it 50 miles or so and parked it overnight and next day it wouldn't start. Was running fine and had no misfiring or noises. I have replaced all the engine electrical and still nothing. I have since done a compression test and have no compression and a lot of fuel in cylinders. I am going to dry out cylinders and try a wet comp. test. Could the floats have stuck open and washed all oil off cylinders to cause this. The oil on stick does smell a bit of fuel..Any help out there would be appreciated as I have had the car only 2 weeks and haven't the chance to even take my wife for a ride in her. Thanks Craig in Vernon BC
Re: engine no start
Sometimes when the mechanical fuel pumps fail they will fill the crank case with fuel too. I'm not sure why it ran and now has no compression.
I always start with two basic things: is it getting fuel? and does it have spark?
Re: engine no start
Has spark and fuel but no fire at all???
Re: engine no start
I'm not sure how far these guys are away from you, but maybe you could get some hands on help if you contact them.
http://www.westerncanadacorsa.com/wcc_news.htm
Re: engine no start
Thanks for the info Scott. I have been in contact with a place called Corvair Specialties in Langley BC. He was supposed to give me an e-mail address for a person in Kelowna BC ,but no reply yet. I'll have to leave it for a few days cause of other commitments. Thanks again Craig
- Gregory_Miller
Re: engine no start
Any update on this? Did you get 'er going again?
