Drivers side window pulled out of pocket
- 66corsaguy
Hello. Ive looked in Clark’s products and i don’t really see what i need or i am looking in the wrong place
The glass pulls right out of the holder. What should i do to get my glass to stay in? Is it a tape or a clamp type thing to hold the glass in?
Any recommendations that don’t require buying OE? Could i use mirror adhesive?
- 66corsaguy
Wagon Master wrote:http://www.corvair.com/user-cgi/search.cgi?part=C772
So does this part kind of squeeze the glass and grab it and hold it tight? Mine is so deteriorated i can’t really tell what the mechanics are
Thanks. I saw the fabric liner they sell but not the rubber. I think i need the rubber?
Re: Drivers side window pulled out of pocket
Windsheild glue will work. So will gorilla glue if you're not concerned with cosmetics. My driver's side is gorilla glued and has been for quite some time. The metal is completely rotten but the glue has held wonderfully.
Sent from my LG-H931 using Tapatalk
-Steve
Clark's C772 is the fabric used to install the side glass in the channel. Windshield urethane will also work.
You might find the procedures and answers you need in the attached 1966 Fisher Body Service Manual section. it was divided into four segments to make the file size small enough to be uploaded on the Corvair Forum. The complete 1966 Fisher Body Service Manual can be found and downloaded using the link below...
viewtopic.php?f=225&t=6007
You might also try the Corvair Ranch to see if they have anything that could help you...
http://www.corvairranch.com/
1079 Bon-Ox Road, Gettysburg, PA. 17325 USA
Phone: 717-624-2805
Email: findit@theranch.today
Our hours are Monday thru Friday 9 to 5, Saturday 9 to 12
or contact us for an appointment.
Phone: 717-624-2805
- 1966 Fisher Body Service Manual - DOORS - Part 1 of 4.pdf
- (6.71 MiB) Downloaded 23 times
- 1966 Fisher Body Service Manual - DOORS - Part 2 of 4.pdf
- (9.83 MiB) Downloaded 20 times
- 1966 Fisher Body Service Manual - DOORS - Part 3 of 4.pdf
- (6.52 MiB) Downloaded 17 times
- 1966 Fisher Body Service Manual - DOORS - Part 4 of 4.pdf
- (9.68 MiB) Downloaded 15 times
- 66corsaguy
Thanks everyone i will most likely use a glass glue since it’s hidden
You must be careful to make sure that the window is high enough and even in the track to close properly after the windshield urethane dries. Best way is likely to remove the seat (for good access and door panel, install the urethane in the track and glass into the urethane and roll the window all the way up with the door closed (no forcing). You can then shift it around a little for a good fit to the vent window and rear glass and weatherstrips, and then leave it that way until it sets.66corsaguy wrote: ↑Fri Dec 08, 2017 5:58 am Thanks everyone i will most likely use a glass glue since it’s hidden
- 66corsaguy
Smart idea. Would hate to have thought of that after.terribleted wrote:You must be careful to make sure that the window is high enough and even in the track to close properly after the windshield urethane dries. Best way is likely to remove the seat (for good access and door panel, install the urethane in the track and glass into the urethane and roll the window all the way up with the door closed (no forcing). You can then shift it around a little for a good fit to the vent window and rear glass and weatherstrips, and then leave it that way until it sets.66corsaguy wrote: ↑Fri Dec 08, 2017 5:58 am Thanks everyone i will most likely use a glass glue since it’s hidden
