Strange oil leak
Strange oil leak
I have developed a small leak on the lip of the top shroud between the distributor and the pulley. It doesn’t seem to be coming from the oil pressure switch or the fuel pump. I’m at a loss to figure this one out. All fitting to the fuel pump are dry. The tightning nut for the tension pulley is wet, how could oil or gas be coming from there? Any ideas or suggestions would be appreciated.
Jeff Cannon, Smithfield, VA
1966 Corvair Monza Conv.
Jeff Cannon, Smithfield VA
1966 Corvair Monza Convertible
Re: Strange oil leak
Under the shroud are some possibilities. There is a bearing in the top cover, holding the fan. Around the top cover about a dozen bolts that hold the cover to the top of the block assembly. If there were a leak around the gasket between the top cover and the block, the air pressure from the fan could cause the oil leak noted.
Wouldn’t that cause a leak under car as well? I’m totally dry under car.Jerry Whitt wrote:Under the shroud are some possibilities. There is a bearing in the top cover, holding the fan. Around the top cover about a dozen bolts that hold the cover to the top of the block assembly. If there were a leak around the gasket between the top cover and the block, the air pressure from the fan could cause the oil leak noted.
Not if gasket is only seeping.
most likely engine top cover or oil filter adapter leak.
Check the oil pressure sending unit too. Also the distributor O-Ring might be leaking. I'm having a heater oil smoke smell myself & thought it was the PCV tube coming out of the side of the crankcase cover but when I pulled the fan shroud all the cover bolts were loose & it's leaking enough oil to get 4 cylinders wet. I ordered a new PCV tube O-Ring but the old one is dry. Hope I can get the oil cleaned off the cylinders. It was 60 degrees Monday but dropped to the low 30's today with snow coming Wednesday, might have to fire up the kerosene heater to finish the job.
My parts books and tech manuals do not show a distributor O ring.
Correct, the distributor uses a gasket not an o-ring. That leak would be a little low to get on the engine number area anyway (unless blowing there).Jerry Whitt wrote: ↑Tue Dec 05, 2017 10:23 pm My parts books and tech manuals do not show a distributor O ring.
Auto supply stores sell a dye that can be added to the oil and with a UV light you can trace an oil leak. They sell the whole kit (dye, light, tinted glasses) for under $20.
Jeff
Jeff
1965 140 Corsa
1965 Corsa Convertible
1966 Crown V8 383 435hp
1986 Buick GN V6 600hp
Well crap, I meant to say the fuel pump O-Ring not the dist.!!!
Great suggestion, looks like adapter gasket at this point.
Strange oil leak
I have removed the oil filter adapter and top shroud. Looks like it was the adapter seal that was leaking! Anything else you think i should do while i have the top off?jcannon44 wrote:Great suggestion, looks like adapter gasket at this point.
Found a small crack in the fan housing, is this serious? Please let me know what you think! See attached photo.jcannon44 wrote:I have removed the oil filter adapter and top shroud. Looks like it was the adapter seal that was leaking! Anything else you think i should do while i have the top off?jcannon44 wrote:Great suggestion, looks like adapter gasket at this point.
Strange no one has mentioned this, but to me the rubber hose going into the fuel pump from the main fuel line is a bit unsettling. Please replace it with the continuous all steel original type line. If the fan belt goes off the pulleys or breaks at a high speed, it could rupture that rubber line, sending fuel all over a hot engine.
1964 Monza convertible 110/PG
I saw it but figured being the inlet line the fuel pump couldn't pump anymore fuel so gasoline spill would be minimal but still a fire hazard.
