Hi there, first time posting on the forum with a question... i have a 1964 Monza, 110 hp with a 4 speed gearbox. Planning on dropping the whole engine and transmission out of my monza soon.
Using a transmission jack and think it would be a good idea to know where the ’mid point of balance’ would be of all the engine and transmission is... any one know (approximately)? If i know this then i’ll know where to place the jack and be able to drop the whole engine and transmission by myself
Thanks for any help
Mid point of balance for engine, transmission and gear box...
Re: Mid point of balance for engine, transmission and gear box...
Bottom of the bellhousing.
'64 Spyder Convertible
Roughly this. Depending on transaxle in use (auto, stick, early, late) it will vary a bit forward from the center of the bellhousing. Some transaxles have more weight forward so a little experimentation is a good idea. Place your jack in a likely spot. Remove the rear mount bolt or bolts and loosen but do not remove the 2 nuts at the ends of the trans crossmember. You can now lower the rear of the powertrain a little while it is still secure at the front. Try to lift the rear with your arms and judge from there where to move the jack for better balance. It is easy enough to jack the rear back up the 3-4 inches you let it down, stick the nut or nuts back on and reposition the jack for a better balance. davemotohead on this forum has produced and sold some nice steel brackets made to support the transaxle on top of a trans jack. Works great.
Davemotohead posts here makes a real nice frame to use with a floor jack.
Many use a lift cart from Harbor Freight.
What ever you do - DON'T PUT SUPPORTS AT THE OIL PAN. I've thrown away a few oil pickup assemblies that were crushed by folks lifting at the oil pan (pickup is only about 1/8" above oil pan).
Welcome to the Corvair Forum!
I have attached several documents that may be helpful to you. The first, Corvair and Corvair 95 Power Train Removal & Installation, is a good supplement to the information in the shop manual. Page 10 (bottom) illustrates the balance point (front to back). The oil pan drain plug is a good side-to-side reference point. After you have removed and disconnected everything around the perimeter of the powertrain and engine compartment that links the engine and transaxle to the car, you can position the jack (and a piece of plywood, if needed, to protect the underside of the engine), in the "best guess" balance position. Remove the three attaching nuts that secure the front transmission mount to the two rubber mounts, and the rear center rubber mount to the engine. As you slowly lower the powertrain, observe the front and rear attachment points to see of the powertrain appears to be coming down evenly. If the rear or front comes down first, you can raise the powertrain again, temporarily reinstall the three attaching nuts, and then make an adjustment to the jack position. After a little trial and error you should see the entire assembly coming down evenly so that it can be slowly lowered to ground level and wheeled from under the car. The shift linkage at the front of the manual transmission tends to hang up on the transmission mount, so you many have to maneuver the hardware a bit to clear the two components on the way down. (One or two safety observers/assistants is nice to have around, but I did manage to remove the powertrain by myself for the first time in 1969 when I was sixteen and survived to tell the tale! I was definitely sweating a lot and showing signs of being nervous at the time, but it can be done).
When you separate the engine form the transaxle, use caution. The problem with the manual transaxle is that the long input shaft (23-24 inches) tends to remain embedded in the pilot bushing and clutch disc, while the other (smaller) end of the splined shaft pulls free from the transmission. As the two heavy components separate, any misalignment that is permitted risks leverage being applied by the input shaft against the throwout bearing shaft, which can fracture this machined casting. Replacing a damaged throwout bearing shaft requires dismantling the differential.
Use caution when separating the heavy transaxle from the engine. If the input shaft remains embedded in the clutch, you must pull the transaxle straight back about 24 inches until the other end clears the transaxle. If you have an assistant, the assistant may be able to reach between the differential face and the bell housing to grab the input shaft and pull it free from the clutch assembly — reducing the risk of damaging the input shaft, clutch disc, or throw-out bearing shaft.
With the engine and transaxle separated, be sure to inspect the throwout bearing shaft completely for cracks or fractures. The input shaft seal should be replaced when doing a clutch job, to ensure that no gear lube will leak onto the clutch assembly during operation. Also, when prying the input shaft retaining ring and seal out, be careful not to apply leverage against the end of the throwout bearing shaft, as excess leverage with a screwdriver or similar tool could conceivably cause a crack to form on the throwout bearing shaft.
viewtopic.php?f=225&t=6007
I would like to encourage you to expand on your earlier posts and tell us more about yourself. If you can describe your personal assessment of your mechanical skills and abilities, that would help a lot. Members of the Corvair Forum love to be helpful in assisting other Corvair owners with technical support and advice, but it helps a lot if we have some understanding of your technical background and mechanical abilities, Corvair-related knowledge, etc. Helping us to know more about you will help us to write comments to you that are tailored to your needs and experience. Knowing your specific location is also useful, because knowing where you live can sometimes suggest possibilities.
- Corvair and Corvair 95 Power Train Removal & Installation.pdf
- (3.35 MiB) Downloaded 33 times
- 1961 Chevrolet Corvair Shop Manual - Section 6 - Power Train.pdf
- (704.51 KiB) Downloaded 20 times
- 1964 Supplement - Chevrolet Corvair Shop Manual - Section 6 - Power Train.pdf
- (32.63 KiB) Downloaded 17 times
Thanks for the info guys :)
