Motor Oil
Jeff+Carrie'63
Motor Oil
Post by Jeff+Carrie'63 »
I have seen a range of oil weight used for Corvairs. I just picked mine up Sunday and the guy I bought it from was using Full Synthetic Motorcycle 20w50. I have not found that weight recommended anywhere, and I don't have the repair manual for the car, so I thought I would just ask those more knowledgable on here. What weight oil should I be using in my 1963 Corvair Monza 900? I am in southern Indiana where we have hot summers and fairly cold winters at times. I know climate locations makes a difference in the weight.
Thanks.
Re: Motor Oil
Below are the recommendations from the 1962-1963 Supplement - Chevrolet Corvair Shop Manual - Section 2 - General Lubrication manual (attached)…
Lowest anticipated
temperature during
time oil will be in
crankcase
32°F........................ SAE 30.......or......... SAE 10W-30
-10°F....................... SAE 10W....or......... SAE 10W-30
Below -10°F............... SAE 5W......or......... SAE 5W 20
1961 Chevrolet Corvair Shop Manual - Section 2 - General Lubrication.pdf
(722.9 KiB) Downloaded 29 times
1962-1963 Supplement - Chevrolet Corvair Shop Manual - Section 2 - General Lubrication.pdf
(161.33 KiB) Downloaded 35 times
what is the best oil for my 64 vair
:link: http://corvaircenter.com/phorum/read.ph ... 142,331359
Selection of the Right Motor Oil for the Corvair and other Engines
:link: http://www.widman.biz/Corvair/English/Links/Oil.html
Selection of the Right Motor Oil for the Corvair and other Engines - Richard Widman.pdf
(2.38 MiB) Downloaded 43 times
Jeff+Carrie'63
Re: Motor Oil
Thank you, sir! Appreciate the help!
