Where does this bolt go?
I think it is from the transmission mount. It needs to be replaced, anyone know where I can get one?
64 Monza Convertible
Re: Where does this bolt go?
Everything corvair is standard, so probably homedepot. If not, fastenal or McMaster Carr.
-Steve
GRADE 8 Bolts Recommended.
http://www.corvair.com/user-cgi/catalog ... _page=167A
http://www.corvair.com/user-cgi/catalog ... _page=179A
Part number C6891: BOLT SET-TRANS TO CROSS MEMB 60-65 STD
Weight: 0 lbs 4 oz
Catalog Pages(s): 167A,179A
Price: $ 4.30
Weight: 0 lbs 4 oz
Price: $ 4.30
If it is from the transmission mount, remove one of the other bolts and use it to check the threads in the hole, you may need to get a helicoil or drill and tap the hole for the next larger size.
'64 Spyder Convertible
The smooth small diameter end is a self centering function.
If you look at the bolt cap you should see the "Grade" marks. I suspect the bolt will be grade 5 or grade 8 - DO NOT use a cheap hardware ungraded bolt.
Yes the bolt hole threads probably need to be cleaned up with a tap. If lucky that will work - if not the hole can be repaired.
I should have provided more details. I removed the drive train in my 64 Monza to get my differential and transmission rebuilt and I noticed this when I was cleaning all the hardware. It is a grade 8 bolt, and the smooth tip makes me wonder.
