How do I install the repro Clarks wheel opening trim for my monza. It is the 66 model that is all one piece.
Wheel trim
Re: Wheel trim
Sheet metal screws. Buy the right ones. There ae probably holes there already. You may need oversize ones if available from Clarks
Frank Metasavage
66 Corsa 140 4 speed Stock
Re: Wheel trim
Clark's sells the proper screws. The heads are shallower than a regular sheet metal screw so they will not show as much. Use existing holes in the body if present or drill new ones if needed.
