Hi Guys,
Just drove my 63' from SF to LA. Drive was smooth with no issues. Now, when the car is just started and idiling, there's a random buzz every 10-20 seconds. I've uploaded a video to YouTube (link below). You can hear the buzz noise first around 00:10, then a few short ones at 00:27, 00:48, 01:00, and 01:20.
Does anyone know what this is? I don't hear anything while driving or while idiling after being driven. I haven't had time to take it to the mechanic yet.
https://youtu.be/-r1kdxCBw0o
Thanks for the help!
63' Spyder - Strange Engine Noise (link to audio)
Re: 63' Spyder - Strange Engine Noise (link to audio)
Sounds like a dry or failing blower bearing.
Jim Thomas
Bethel, VT
63 Monza Coupe
Bethel, VT
63 Monza Coupe
If the noise is associated with a bearing (fan, idler or generator) and it recurs frequently, you should be able to remove the fan belt and run the engine for a short period of time to see if the sound has been eliminated. A mechanic's stethoscope (or a suitable substitute, as described in the video below) can help you to isolate the specific source of the noise. These stethoscopes are listed on Amazon.com for about $7.00 - $20.00.
https://www.amazon.com/s/ref=nb_sb_ss_c ... SE7CNQRQQ6
sounds like a voltage regulator buzzing? get your ear that that & see if the buzz is coming from it.
with a cold engine....remove the fan belt. run the engine w/o the fan belt for a minute or so. if the buzz isnt there then its prob not coming from the engine but from something else..............like something hooked up to the fan belt.
-Scott V.
-Scott V.
Update: I ordered a mechanic's stethoscope, but I haven't heard any buzz/howl since the weekend; even when starting the engine cold. After some more digging, I'm guessing it is a fan bearing "howl." I've found quite a few threads on this after seeing the recommendations above. Thanks for the quick help!
Someone else posted this audio clip of a fan bearing that's going bad... Sounds like mine:
http://autoxer.skiblack.com/nallm/Turbodynomax.wav
