Steering box
Steering box
Steering box is weeping - my question is buy a "new" one or replace seals. Thanks in advance.
Dave Thompson '64 Monza Vert
Steering box
Mine craps grease mix out of the bottom. I just keep it filled. There's no play in it otherwise. It's your call. If there's no play maybe you could just clean it all and reseal it.
I see the zerk fitting is that to add more grease? Mine doesn't have that, and I fill it with the recommended mix of gear oil and grease.
-Steve
Re: Steering box
I just added new gear oil to my steering box. I used this:
You can get it from: http://www.restorationstuff.com
It is part # LUB009.
It will cost you - their shipping is expensive but it seems like good stuff and the claim is it controls leaking. I haven't had it in there long enough to know if that is true or not.
Alec
Alec
Alec Carlson
Dahlonega, GA
Restoration "In Progress"...
Dahlonega, GA
Re: RE: Steering box
Thanks. Not sure about the zerk fitting - came with the car....along with badly fixed floor panels covered with a whole lot of bondo.[emoji36]lostboy wrote:Mine craps grease mix out of the bottom. I just keep it filled. There's no play in it otherwise. It's your call. If there's no play maybe you could just clean it all and reseal it.
Sent from my SM-T350 using Tapatalk
Re: RE: Re: Steering box
Thanks - I will look into this.acarlson wrote:I just added new gear oil to my steering box. I used this:
Alec
Re: Steering box
Bondo on/in the floor? lol that's awesome.dmt98239 wrote:Thanks. Not sure about the zerk fitting - came with the car....along with badly fixed floor panels covered with a whole lot of bondo.[emoji36]lostboy wrote:Mine craps grease mix out of the bottom. I just keep it filled. There's no play in it otherwise. It's your call. If there's no play maybe you could just clean it all and reseal it.
-Steve
