Have you pulled your gas tank on EM
How long do you think it will take a pro while having on a lift, new bolts, new filler hoses.....
Re: Have you pulled your gas tank on EM
a pro can do it in 1 hr if nothing is rusted. 2 hr if everything goes wrong.
-Scott V.
-Scott V.
Probably 20 minutes, but you can't expect to pay a pro by their time. A gas tank job on any car is probably a minimum of 1.5hrs labor.TheCommish wrote:How long do you think it will take a pro while having on a lift, new bolts, new filler hoses.....
Wait.... did you mean just pull, or pull swap parts and replace? For the whole r&r I would refer to the other posts 1-2 hours.
-Steve
Not exactly sure what model you have but be careful if it has the vent/return line attach as well. It will be above the larger filler line. Double check before trying to yank Gas tank out.
Sent from my SAMSUNG-SM-N920A using Corvair Forum mobile app
Christopher Hunt
San Diego, CA
'63 Monza Spyder 150HP Turbo
San Diego, CA
Also is your EM equipped with a front sway bar? That will add some time to the R & R.
