Rockers getting stuck
I have had this problem be for with my 65 monza 110. Last time, one of the rocker balls got stuck in the rocker and started making this huge whipping sound with nearly no power at all. I am now starting to hear it again in the cold mornings. Can I convert to roller rockers? Or should I just get all new original rockers?
Re: Rockers getting stuck
Converting to roller rockers is not always an easy conversion. I would be worried about why your's are locking up. Do you have insufficient oil coming up the pushrods? That could cause a roller rocker to lock up too so it might be best to confirm good lubrication first and then just replace the bad rockers with new. No reason they should be failing again.
Yea, I made sure they are getting lubricated but they look very warn out.
sounds like the engine has other problems.........the stock rockers are a result.....not the cause.
stock rockers will go 70k miles - no problem. somethings wrong w/your engine & that needs to be fixed before you do something else like install more rockers.
how do you know the rockers are getting lubricated?
did anyone work on the engine & maybe put the pushrods in wrong/upside down? theres a oil hole on the end/side of the pushrod & this has to be next to the rocker.
-Scott V.
-Scott V.
I had them out to clean them and put them in so that the little hole squirts oil on the rocker while running.
I think that someone we abusing it pretty badly before I got it. There's nothing left on the rocker that froze up. This car does have 72,000 miles.
They may have rpm'd it because I found a few bent push rods.
If it was my engine, I would remove each of the rockers, one at a time, so you don't mix the parts up. Inspect the balls for galling, pitting and wear. Inspect the rockers for galling, pitting, and wear in the pocket. Also inspect the pocket, top and bottom for cracks. Check the rocker tip, the valve end for excessive wear. There will probably be some wear in that area. A shallow smooth edged cupping is to be expected. Sharp edges are a reject. Double check the push rod installation and make sure the oil passages are clear.
Chris Brown
Member
CORSA
Member
CORSA
