Cad-kid's 65 Monza - my first Corvair
Re: Cad-kid's 65 Monza - my first Corvair
While I was in the process of taking out the fuel sender I tried to pull out a little more wire. So since it wouldn't budge I took off the pan to see if something was tangled. No luck but I did find another mice nest Now I know why the seats are kind of flat
Also I found out why the fuel gauge was semi stuck - the sender housing was totally full of junk
The tank was cleaned and sealed by the po.
A new sender from one of our fine venders will fix it up
- Am-Iron
Nice score! I have the tunnel off of mine today to replace the shift rod bushings and coupler pin. Yours will come together quickly once the weather breaks!
Thanks Am-Iron. I have been working on other areas of the Vair that I haven't started on my carbs yet
- Corvair.crazy
Hey, Jeremy I been watching waiting all winter for you to start. Nice find on the sending unit. Sometimes it is the simplest of stuff.
Jon
CORSA member
1962 Spyder convert
1961 Rampside
CORSA member
1962 Spyder convert
1961 Rampside
Thanks Jon. Even though it has been below normal temps (around freezing now) - it has been a good release to work on the Corvair.
Today I decided to do a compression check now that the heads are torqued down, the broken push rod is replaced and the valves have been properly adjusted
-to recap - the first compression test I did (last December) was 1-145, 2-135, 3-30, 4-150, 5-90, 6-160
Today it was 145,140,145,160,160,165
I am curious to see if it changes after some good fun driving
Hopefully by this weekend I will have the carbs done and the engine running
- Corvair.crazy
That is a testament to these engines. They are very resilient. I hope you drive goes well.
Jon
CORSA member
1962 Spyder convert
1961 Rampside
CORSA member
1962 Spyder convert
1961 Rampside
Here are some showing the carb cleanup process. I have been wanting to use my ultrasonic cleaner on some carbs since I purchased it two years ago
The carbs turned out great but the solution I used (simple green Pro HD) only softened up the black stuff in the throat of the carb. A simple old tooth brush and some light scrubbing easily took care of it.
Well I have had my Vair out about 3 times now Comparing it to the cars I test drove I feel like I have a strong runner here
There is still much to do on the mechanicals - there is a 2 drop oil leak at the crank pulley end that is not the crank seal or oil cooler. I think it is part oil pan gasket and possibly part rear engine housing gasket.
Then there is the 20 year old tires I picked up a set of Olds 14" rally wheels that I am in the process of cleaning up. These came with all the stainless steel trim bits (bonus!). I haven't had the car above 40 for more than a few seconds as there is some bad vibrations from those tires. I can tell this Monza wants to run free (big grin on my face when ever I drive it).
Enjoy the photos - I call this the NASCAR "look"
After a few hours work (mostly on the bead edges) these rims are looking great!
I'm jealous! I'm anxious to drive mine...Still working on the motor! sigh.
Your car and wheels are looking great!
Thanks Scott. Working on the Vair after work has been a good way to relax and "wind down".
I'd love to relax and wind down working on the car - but then my kids find me and it's all over!
Drove the Vair to work today The new tires and rims work great! Before with the 20 year old 13" tires I could not and would not drive at highway speed - vibration plus the knowledge on how bad those tires were. The tire size I chose was 205/70R14. They seem to fit great even though the backspacing on the rims was a bit under 4 inches.
The trip went great today. I still have several things to work on but getting the car to this stage is a great encouragement. As I have read here and elsewhere - get your vair drivable and you will get much more enjoyment out of the project and repair process.
Excellent to see it out and about! That's a great pic there also!
Thanks! After I saw the photo on the computer screen I thought "WOW". Nice color and subject variety. And some big N little
Looks great! I looked for red cars when I found mine and I was thinking "SO, THAT is what my car would look like if it still had paint and an interior, lol".
Great job!
Great job!
Thanks, there will be a big update soon. Heads have been rebuilt by Ken, plus I have been doing much work while the engine is out - hope to have it back in soon.
