Project: 1964 Corvair Monza 900 coupe in Hot Springs, AR
TexasUK
Re: Project: 1964 Corvair Monza 900 coupe in Hot Springs, A
Unread post by TexasUK » Mon Sep 03, 2012 1:51 pm
I had to buy a second hand defroster duct for under the drivers side, and replace the ducting to both as well. It isn't that difficult or strenuous, just need a little brute strength. I used the newer rubber type, looks good.
I'd recommend flattening the duct end before fixing to the duct, the length that Clarks supply it at is just about perfect for both sides.
I also found that my heater blower worked today, and that it didn't work through the switch. I wired directly to a power source and went throught the switch to the fan supply,so that at least it looks stock. My thermistor has fallen apart, it is only mounted on card, and it had just gotten too brittle. I've ordered a new one, hopefully it will make it all work again.
Unfortunately the feed I wired the new feed too had a 10 amp fuse in, and that blew, so can I presume that it is safe to just keep upping the fuse size until it keeps working? Does anyone know what fuse should be in the heater fan feed?
I haven't seen a good description of picture of the fuse box in a 64 vert, and I have even bought one of those coloured wiring diagrams from ebay. if anyone has one or can point me at one then I'd appreciate it.
RedLightBrew
Unread post by RedLightBrew » Tue Sep 04, 2012 5:10 pm
Here's the underside with oil pan off. Not terribly sludgy.
RedLightBrew
Unread post by RedLightBrew » Tue Sep 04, 2012 5:13 pm
[can I clean some of that up without hurting anything? Brake cleaner evaporates completely right?
Bobby65
Unread post by Bobby65 » Tue Sep 04, 2012 6:20 pm
yes, brake cleaner is fine
Drive it like you stole it
65 Turbo Monza Coupe
64 monza convertible 4 spd
Grand Ledge, Michigan
RedLightBrew
Unread post by RedLightBrew » Thu Sep 06, 2012 9:45 am
New wheels an tires leaving Ohio today. They say 4 business days or deliver. That's ok. I have plenty of work to do to get it rolling anyway.
RedLightBrew
Unread post by RedLightBrew » Fri Sep 07, 2012 7:08 pm
Put new oil pan gasket on. A couple of the bolts seem to be on the verge of stripped. I got them tightened up as much as I could, the rest torqued up to about 30 ftlbs. Doesn't seem to be any major leaks yet. Working on tune up now. Need to go get the compression tester from auto parts store in am. Timing was WAY off the scale. It wouldn't idle at the 4+/- as the book says. I got things adjusted where it will idle just over 4 now, but now I have a bit of a back fire out of the right carb. Using the Uni-syn to balance things, but I'm not sure what I'm doing. :dontknow: And the idle seems a bit high. I don't have a tachometer to check it. Anyway, just a few things I'm dealing with right now. Any comments or suggestions would be appreciated. Thanks! :checkeredflag:
1964 Corvair Monza 900 Coupe (bought 2012)
1962 Corvair Monza Spyder Convertible (sold 2002)
RedLightBrew
Unread post by RedLightBrew » Sat Sep 08, 2012 5:20 pm
Lots of pictures. Just several of the projects I am or have been working on. Note the heater blower is not terribly difficult to get to on the passenger side with wheel removed. Someone wanted some info on that a while back. Coming together. Still lots to do before I can drive it. That's ok it's been great therapy working on this.
TexasUK
Unread post by TexasUK » Sun Sep 09, 2012 11:42 am
I was the one who asked about the blower motor, and I also found that I could remove it with the wheel off. I did this and could check that it was working.
I also appear to be mirroring your experience over here in the UK, with a 64 as well, but mine is a convertible, so a few differences in construction.
My oil pan had a single bolt stripped that someone had put a longer bolt through and a nut on the other side, so that might be a viable solution if one goes.
I'm not sure what you mean by 4, is that degrees? It should be 16 as far as I know, and it runs fine at that.
RedLightBrew
Unread post by RedLightBrew » Sun Sep 09, 2012 12:41 pm
These are the tune up specs in 64 book. Mine is 4spd. What am I shooting for?
RedLightBrew
Unread post by RedLightBrew » Sun Sep 09, 2012 12:43 pm
This is from the 61book.
TexasUK
Unread post by TexasUK » Sun Sep 09, 2012 1:01 pm
Well these look different - http://www.carnut.com/specs/gen/vair60.html
I've never seen those specs before, they look like they are for an auto?
From the specs in the link above it says 12 degress, ive set mine a little nearer to 14, as it seems to run well at that. I guess there would be no harm in you at least trying it.
RedLightBrew
Unread post by RedLightBrew » Sun Sep 09, 2012 3:58 pm
It was set way past the scale when I initially checked and it didn't run too bad. Now it's at 5ish and runs rough. I'll set it to 12-14 and see how it goes. Thanks for the info.
Unread post by cad-kid » Sun Sep 09, 2012 4:39 pm
RedLightBrew wrote:Lots of pictures. Just several of the projects I am or have been working on. . Coming together. Still lots to do before I can drive it. That's ok it's been great therapy working on this.
You are making some great progress. I noticed your fuse block really needs some attention :pray: (corroded terminals)
CORSA Member#031129
RedLightBrew
Unread post by RedLightBrew » Sun Sep 09, 2012 5:06 pm
YES!!! It's bad! Thinking about new harness with fuse block. Any good sources besides Clark's? Theirs is kind of pricey.
Unread post by bbodie52 » Sun Sep 09, 2012 8:33 pm
For electrical components, wiring harnesses, etc. you might check out the Corvair Underground catalog, pages G-1 - G-32.
http://www.corvairunderground.com/
Or contact them at 800-825-8247 or sales@corvairunderground.com to discuss your needs. :helpsos:
RedLightBrew
Unread post by RedLightBrew » Tue Sep 11, 2012 4:00 pm
New wheels. Preview: discount tires direct was easy to work with and delivered quickly with the best prices I could find and free shipping. Can't beat that. I'll take more Pics when it's off the jack stands.
