Project: 1964 Corvair Monza 900 coupe in Hot Springs, AR
Re: Project: 1964 Corvair Monza 900 coupe in Hot Springs, A
S-W-E-E-E-E-E-E-E-E-E-E-E-E-E-T !!!! Enuff said!
Mark M
63 Corvair Monza Spyder
East Texas
East Texas
Yep they look SICK!!!!
- RedLightBrew
Thanks guys! More pics of this project as I go.
- RedLightBrew
Wheels turned out good. New plugs and wires in. Had to helicoil one plug. Compression is even across all cylinders. Now on to finish up the interior.
- RedLightBrew
Pics. Kind of weird, the right rear wheel is a little bit further outboard than the left. About a half inch. Seems a little odd. Not really noticeable but of course I noticed. I drove it some today and there is a leak between the engine and transmission. I think it's gear oil but not positive yet. It drips for about 10 minutes after I park it and then stops. The fuel pump is leaky, so ordered new. Still need to do the PCV/crank case vent hoses. Drives great, but breaks pull right slightly. I wonder if front left needs attention? I'll get it all worked out.
- TexasUK
Did you change the timing?
- RedLightBrew
I set the timing to around 12 and it runs pretty good. A little backfire from right carb once in a while. I'll work on it again when fuel pump gets here.
1964 Corvair Monza 900 Coupe (bought 2012)
1962 Corvair Monza Spyder Convertible (sold 2002)
- RedLightBrew
Things to do:
New fuel pump when it arrives.
Dual master cylinder upgrade already here but not installed.
Rebuild all wheel cylinders and replace rubber brake lines.
Fine tuning on carbs.
Cut out drivers side floor panel and weld in new.
A little sound proofing and Reinstall all interior.
Stereo. ATO fuse block.
That should keep me busy for several weekends.
- ncwitte
You're really going to town on this. Those rims and tires are some of the best I have seen on an EM. It really looks nice with them.
Norm Witte
Lansing, Michigan
http://www.wittelaw.com/personal
viewtopic.php?f=52&t=4208
Lansing, Michigan
That is sweeeeeetttt! It makes me miss the yellow convertible I sold last year. You're going to have one nice ride.
- RedLightBrew
Cleaned up and organized a little today.
You could use some more shelving Thanks for the photo - My workspace could use a good cleanup as well
- RedLightBrew
Shelving to the right continues over about 8 more feet. and another 18x24 workshop behind that back wall in the garage. This is just where I'll park the car..
- 65corvaircopnj
Looks like you're doing great! Lotsa little stuff but nothing major!
I just scoooped up a 63 (see 4/sale in VA) coupe and have yet to dig into it. The wheels look hot! What brand?
Hoping to make it a semi-dependable DD as well. Good luck, I'll try to post m progress as well
Chris
55 Belair Sedan
Used to have: 65 Monza Convertible; 66 Monza Cp w A/C ; 63 Monza Cp
55 Belair Sedan
- RedLightBrew
Wheels are Drag DR-27.
- RedLightBrew
Installing dual master cylinder today. I have access to a reverse brake bleeder. Seems like the way to go. What fluid are you guys using? DOT2? 3? Silicone? Any bench bleeding advice on this? Do I still need to bench bleed with reverse brake bleeder? This is my first experience with brakes.
