65ish Corsa Automatic
Re: 65ish Corsa Automatic
The chart referred to above is incorrect where it indicates that the 1965 Monza and Corsa interior code 798 is "Ivory". As shown in the chart below (from the 1965 Chevrolet Corvair GM Heritage Center Specs) indicates that code 798 is a two color black and white combination, with the carpet and instrument panel black.
- (2.01 MiB) Downloaded 36 times
Perfect! THAT is what I needed! Thanks to all for the help!
and so this car was DD exterior color Mist (Med) Blue... cool
CORSA Member #034095
With a little help from my Daughter we layed out the Yenko stripe
this is 16ga steel (cause i have lots) First test fit, seems like I imagined it Rust coating done. Now it needs the wooden drink holder inserts, the top hinged cover, and it's white and black fabric covering. and finally, got the Frunk mostly sorted out
FLat White was SO the right choice instead of the usual black.
I decided this car need a center console and drink holders (front and rear)this is 16ga steel (cause i have lots) First test fit, seems like I imagined it Rust coating done. Now it needs the wooden drink holder inserts, the top hinged cover, and it's white and black fabric covering. and finally, got the Frunk mostly sorted out
Man Steve, where did you get a hold of that nice long anvil? I bet that comes in handy for doing sheet work! Btw the stripe is looking good.
Ed Stevenson
Ed Stevenson
I've been making armor for more than 25 years so I have a bit... that is called a beakhorn, I also have a blowhorn which is the stake used for making trumpets and other wind instruments. I have about a dozen or two homemade stakes specifically for the components that I make, so yeah hand metalworking wise I've got lots of toys
Cool,looks good with the white stripes!!
1960 500 coupe 3spd
1960 700 sedan pg.
1962 Monza coupe 4spd.
1962 spyder convertible
1964 Monza coupe pg.
1964 Monza convertible 4spd.
1966 corsa coupe turbo
1960 700 sedan pg.
Good idea on the stripe layout!
Solved the harsh downshifting into 1st.... The Vacuum modulator works WAY better when the connector hose is actually connected.... MUCH smoother now... LOL
The engine is running better than ever but there is still a slight "lope" when sitting at stoplights/signs. Occasional misfires as well...
Birthday Upgrades!!! Front Air Dam, 15" Crager S/S's and 205/60R15's
Love my wife!!!
Love my wife!!!
Cool!! Congrats and happy birthday!!
1960 500 coupe 3spd
1960 700 sedan pg.
1960 700 sedan pg.
Center console done. Will be installed Tomorrow after she gets out of the shop.
Took it to a GREAT local shop, same day service $190 to cut 1 coil from my fronts. I got a 1.25" drop.
Waiting until they close be stored inside waiting for the first AM appointment for brakes and alignment
Steve - similar to the "Field Find" you continue to inspire and amaze... Really good looking vehicle...
BobWitt - South East Michigan
Member: Corsa and DACC
1966 Corsa 140
1966 Corsa 140
home!!!
Car is looking really good!! Great look!
1960 500 coupe 3spd
1960 700 sedan pg.
1960 700 sedan pg.
Thanks! Here it is with the console in place.
Getting one step closer to the point where I'm gonna have to change the thread title....
BIG thanks to Paul Kehler who provided these for only $250 each exchange!!!!
