65ish Corsa Automatic
SteveH
Unread post by SteveH » Mon Sep 19, 2016 1:00 pm
I just bought this 65 Corsa (that looks suspiciously like a 66) which was converted to a PG Automatic
CL Exterior.jpg (47.8 KiB) Viewed 1205 times
The bendix on the starter is failing but it still starts and it will not idle long because one of the driver side carbs has a stuck float (or some other reason that it is just DUMPING fuel into the head) I have the 4 carbs off of my Field Find 65 Corsa and am rebuilding two tonight. This should let me get the car running enough to get me home.
These are the 140's from "Field Find"
This is the inside, oil POURED out of this when inverted
I think I can spot the one that had the first round of cleaning. I picked up a pair of rebuild kits today (they only had two) and am hoping to get both finished being rebuilt this evening
The DMV today was a joy.... It is an expired reg, out of state car. always a challenge. I now have a moving permit for one day (of my choice) so I can drive it to the DMV for VIN verification. THEN they will put it in my name and give me Cal plates and stickers. Sigh.
CORSA Member #034095
SteveH
Re: 65ish Corsa Automatic
Unread post by SteveH » Mon Sep 19, 2016 1:28 pm
Build Tag
SteveH
Unread post by SteveH » Mon Sep 19, 2016 1:42 pm
If I have this correct:
65 Corsa hardtop
TRim 798 ??
Paint D-D (Red)
ACC:
Tinted windows
4 speed
2 spd wipers
washer
day/night mirror
Padded dash
Spare tire lock
Unread post by azdave » Mon Sep 19, 2016 3:00 pm
It does look like a 66 in that pic. Does it have the mystery air box in the back and the slanted voltage regulator?
65 Corsa 140 4-speed
66 Corsa 455 Toro V8
65 Monza 455 Toro V8
65 Monza 4DR EJ20T w/5-speed
SteveH
Unread post by SteveH » Mon Sep 19, 2016 3:48 pm
well now... Two terms I have not heard before.... I will get pics when I am back up there to pick it up. (HOPEFULLY the two rebuilt carbs will let me drive it home)
Unread post by azdave » Mon Sep 19, 2016 5:33 pm
SteveH wrote:well now... Two terms I have not heard before.... I will get pics when I am back up there to pick it up. (HOPEFULLY the two rebuilt carbs will let me drive it home)
In 65, the voltage regulator was mounted at an angle. Also 65-only, a fresh air intake planned for the heater box was not used and got capped with a small rectangular steel lid. You won't see either of those in 66 and up.
This engine is far from stock but it does show those two items.
SteveH
Unread post by SteveH » Tue Sep 20, 2016 10:45 am
I think I am going to call this carb shot.... The support posts for the float are half missing due to corrosion.
Anyone got a spare secondary for sale?
toytron
Unread post by toytron » Wed Sep 21, 2016 8:18 pm
Yeah that looks pretty bad.
Sent from my SM-N910V using Corvair Forum mobile app
xrotaryguy
Unread post by xrotaryguy » Thu Sep 22, 2016 7:25 am
I have a spare. No idea if it's a secondary or of it's condition. (I actually thought the secondaries and primaries were the same) What part of California are you in? I'm in Pomona.
Sent from my SM-G900V using Corvair Forum mobile app
SteveH
Unread post by SteveH » Thu Sep 22, 2016 8:12 am
Thanks! I am in the SF bay Area. Yeah, secondaries are the same casting but not machined the same. Many holes not opened, no choke, no idle mixture screw/hole, etc
SteveH
Unread post by SteveH » Thu Sep 22, 2016 11:56 am
Well, the good news is that I was able to drive 2 hours up to Travis AFB and get the two rebuilt carbs installed on the Corsa...
The bad news is that I left the keys at home.... :banghead: I feel like a total idiot...
We used a jumper wire to turn it over, but it would not "run".
Sigh...
xrotaryguy
Unread post by xrotaryguy » Thu Sep 22, 2016 10:47 pm
Aha, I'll look at the one I have. I'm in the LA area.
Unread post by azdave » Fri Sep 23, 2016 6:30 am
SteveH wrote:Well, the good news is that I was able to drive 2 hours up to Travis AFB and get the two rebuilt carbs installed on the Corsa...
Sigh...
If you got it to turn over, adding a jumper wire from the battery to the coil would have got it started temorarily. If you ran it too long that way the coil could over heat but it works when testing for 5 minutes or so.
Good luck on the carb hunt. I'm keeping the spare secondaries I have for my own use.
Do you know about the HUGE Corvair swap and show coing up in Palm Springs? One of the best places to shop Vair parts. It is late October.
http://www.vintagecorsa.org/
SteveH
Unread post by SteveH » Fri Sep 23, 2016 8:40 am
Thanks, but the goal was to get it to drive home (1 hour+) we need to actually start it the right way.
Heather and I are going to REALLY try to get to the Toss. It would be great as I now have TWO Corsa's to work on!
SteveH
Unread post by SteveH » Sat Sep 24, 2016 8:32 pm
6 days of working, three trips to Travis AFB (1.5 hours each way no traffic, 2.5 each way with)
I have rebuilt two of the four carbs and replaced the starter, and all 6 plugs.
She runs!!! It is now home with me safe and sound. 65-70 the whole way, and only three or four backfires! lol
Still have tuning to do, but it has FOUR carburetors, so yeah...
1965 Corvair Corsa 140 Automatic (converted years ago)
toytron
Unread post by toytron » Sun Sep 25, 2016 4:30 am
She's a beauty.
