PaulR
Post by PaulR »
Hey guys could you please decode this one. I know most of it except for some on the options (last) line. Here goes:
04A B
ST 65-10567 WRN 14834 BODY
TR 773 E-1 PAINT
2M3C4U5W
This one example is pretty rough and it is a parts car only. I may have gotten the "C" wrong in the last line. It was tough to read. Thanks.
1964 Monza convertible 110/PG
PaulR
Re: 1965 Monza Convertible
Post by PaulR »
Apparently when I type in proper spaces and lines, as shown on the Fischer body tag, it does not come up exactly in my post. I love "technology". Sorry about that but you should still be able to decipher it.
04A B
TR 773 E-1 PAINT
2M3C4U5W
BODY TAG INFO:
04A
Body Build Date: 04 = April A = First Week
The first two digits are numbers 01 through 12, indicating the month of manufacture. The letter is A-E, indicating the week of the month. If the letter is an "A" it indicates the first week of the month.
Interior paint code: B = Blue
Style: 65 = 1965 10567: 1 = Chevrolet, 05 = Monza, 67 = 2-Door Convertible 4-Passenger,
WRN = Willow Run, Michigan, Production Sequence No: 14834
1965 Chevrolet Corvair Monza 2-Door Convertible - 4 Passenger, Total Production: 26,466
TRim: 773- = FAWN (MONZA 10500 and CORSA 10700 SERIES — Bucket Front Seats)
This 3 digit codes represents the interior color and seat type.
(Are you sure this number was 773? 733 is the code for Blue).
Paint: E-1 = DARK BLUE "Danube Blue Poly.", Top Color Code: 1 = WHITE
Lucite No. 4631L, Rinshed-Mason No. A1721, Ditzler No. DDL 13002
Example — 1965 Corvair in Danube Blue
ACC = Accessory line
2M 3C 4U 5W
GROUP 1
NONE
GROUP 2
M = RPO M35 — Powerglide Automatic Transmission
GROUP 3
C = RPO B70 — Padded Dash
GROUP 4
U = RPO P19 — Spare tire lock
GROUP 5
W = RPO A49 — Deluxe Front Seatbelts (Chrome Buckles) with Retractors
This guide will show you how to decode the VIN tag...
1965 Chevrolet Corvair Monza Convertible produced at the Willow Run, Michigan Plant, S/N: 164108
I have attached a copy of the 1965 Chevrolet Corvair GM Heritage Center Specs for your model year Corvair.
1965-Chevrolet-Corvair - GM Heritage Center.pdf
(2.01 MiB) Downloaded 32 times
:chevy:
PaulR
Post by PaulR »
Thanks for the run down of the body tag information. Everything checks out; the padded dash, deluxe seat belts, retractors and PG transmission. My bad, the interior code is 733, light blue, instead of 773. The car has been repainted since it is no longer in code E, Danube Blue, it is closer to the code D, Mist Blue. Thanks again.
PaulR
Post by PaulR »
Update: I am going to buy this POS car, (oops, can I write that on here?), before I change my mind. Hopefully in the next couple of weeks when it gets warmer I can drag it home. If you live in east central Wisconsin, please let me know if there is anything on the car that you may want. It is very rough from sitting outside a long time, but all the parts, especially the convertible specific parts are there. More details to follow. Now, if the guy could forget that I am going to pick his car up...
