Big Bore 3.1 HP
Big Bore 3.1 HP
Anyone with a big bore kit up to 3.1 ever dyno there engine or chasis?
Thanks
Thanks
Re: Big Bore 3.1 HP
No response?
No one here into a big bore engine??
- flat6_musik
Re: Big Bore 3.1 HP
I think it's pretty rare that someone is running this setup, that's why the zero response. I'd love to run it someday.
Re: Big Bore 3.1 HP
I know a man that ran a 3.1 in his Ultra Van. I believe he ran it on an engine dyno, I have seen the figures, but, I can't locate them now. PM me with your contact info and I will forward it to him.
Chris Brown
Member
CORSA
Member
CORSA
Re: Big Bore 3.1 HP
Here's a few big bore dyno runs:
http://www.corvairkid.com/190cid.htm
The graph is a bit awkward to read as the vertical scales are different
Here's Duane Cartwright's engine: Duane designed and produced the Cartwright Fuel Injection system
3.1 with modern turbo I'm pretty sure this was built by Ray Sedman at American Pi http://www.american-pi.com/corvair/corvhome.html
Marty Scarr
This is Kent Sullivan's engine in his 66 coupe, you can read about it here: The graph is a bit awkward to read as the vertical scales are different
Marty Scarr
Re: Big Bore 3.1 HP
One more - Mark Wright (solo2r) 3.1 efi NA
Re: Big Bore 3.1 HP
Thanks Marty for posting,
This a turbo motor?
This a turbo motor?
Re: Big Bore 3.1 HP
3rd pic is turbo, all others NA (normally aspirated)
Re: Big Bore 3.1 HP
PM sent Funvairs,funvairs wrote:I know a man that ran a 3.1 in his Ultra Van. I believe he ran it on an engine dyno, I have seen the figures, but, I can't locate them now. PM me with your contact info and I will forward it to him.
Would like to know??
Re: Big Bore 3.1 HP
Shaker455. PM back to you
Chris Brown
Member
CORSA
Member
CORSA
