Career Project...
- Rick Calcitrant
Career Project...
Good day,
This post and attached photos are sequential to those posted in the "introductions" forum under the same heading, "Career Project." Hope you find them interesting...
Over the next several months an AutoCAD file was created to design and engineer a "back-bone" style chassis for attachment of the suspension, engine/transaxle, and as a stiffener to the Corvair's unibody. During this time I was working at an Industrial Design facility that provided contract design and engineering services to the OEM auto design studios located in central and southern CA. I had occasion to befriend an Engineer there by the name of Mark Visconte who had previously worked for Shelby American and was responsible for the suspension engineering on the Shelby Series One car. Fortunately for me, Mark offered to provide his expertise to my CAD file drawings to insure a performance oriented configuration to the suspension layout. The Shelby car used Corvette C4 front suspension components in both the front and rear. The Shelby rear took advantage of the later C4 front knuckles that incorporated ABS sensors that provided a hole through the knuckle that allows a half shaft to connect to a drive hub. Pretty neat arrangement and more geometrically and dynamically efficient than the standard rear configuration in the Corvette. At that time knuckle adapters were purchased from Shelby and hub adapters were machined by the folks at Mark Williams Enterprises to connect the C4 wheel hubs with the Porsche 930 CV jointed half shafts. Simultaneously, the chassis was being fabricated and a reconditioned 930 Porsche transaxle was purchased through eBay. The front and rear sections of the chassis attach to the Corvair's unibody frame members via additional tube links while the center crossmember attaches to the Corvair's sill boxes in line with the rear door jambs.
In addition, quickie epoxy FRP molds were taken from the Corvair's hood and decklid. From the molds we fabricated carbon fiber inner and outer panels that were then joined with structural adhesive. The result was as you'd expect, very light and very stiff. Unfortunately, I'm not diligent about taking photos in the quantity that I should so, as you may have noticed, there are huge blank spots in the build.
- flat6_musik
Re: Career Project...
Oh my god....suddenly I feel like I'm running wagon wheels. LOL
- Rick Calcitrant
Good day Musik,
Hey, I get myself into stuff like this all the time where I've over extended myself financially and also escalated the scope of the project relative to labor. Please know that while you're enjoying your Corvair on the road, I've got a long way to go yet to be able to enjoy the same thing you already have. I don't know why I do it, I just do it; my wife isn't happy about it either. That said, perhaps my neurosis will offer some entertainment and inspiration to the forum. Cheers.
Killer start.........I will be watching
- ncwitte
Wow. This is more ambitious than I at first thought. I'm eager to see how this goes. Keep posting!
Norm Witte
Lansing, Michigan
'65 Corsas: 140 coupe and 180 convertible
http://www.wittelaw.com/personal
viewtopic.php?f=52&t=4208
Lansing, Michigan
holy cow, your doing the right way, its going to be probbly the best setup for a corv8 that has been put together
Drive it like you stole it
65 Turbo Monza Coupe
64 monza convertible 4 spd
Grand Ledge, Michigan
- Rick Calcitrant
I just got around to taking some pics of the car's current condition. There's a significant "jump" from the work completed (and time) in the last post. As I mentioned I'm not very diligent about taking pictures. In this series of pics a substantial amount of bodywork has been completed, and the carbon fiber hood and deck lid have been attached but without proper alignment or gaping. While the pictures don't show them, I've got a couple of kinda' Mickey Mouse hood and deck lid props that I'm not particularly happy with. They're stainless steel and operate via a self locking function that is released by lifting the hood until you hear a "click" and then you can lower it. It works well as long as there isn't a breeze that could lift the hood thereby unlocking the catch and allowing it to crash down. I was going to use gas struts but I'm inclined to believe they might cause the hood or deck lid to distort under pressure when closed; I'll have to give that one some more thought.
This profile shot provides a glimpse of the "backbone" chassis through the wheel wells. I'll post some more detailed pics of the chassis very shortly.
BTW, I have a question for any of you out there that might be Mustang II rack and pinion gurus. I purchased a new rack on eBay some time ago and was intending to change out the inner tie rods to later model T-Bird units that, coincidentally, have the needed length and thread size to mate up to Corvette C4 outer tie rod ends. I had done substantial research online to the conclusion that the T-Bird units would screw onto the Mustang rack in place of the Mustang II inner rods. Well this unit has a different thread size than the T-Bird Inner tie rods so it's a no go. But my question is, by all accounts, this should work, so I'm guessing the Mustang II rack I got is some cheesy knockoff with different threads. The other part of the rack that also contributes to my skepticism is that when I took the rack apart to change out the rods, it had a goofy hemispherical nylon button backed up by a spring that puts a pre-load on the ball end of the rod. I can imagine that thing compressing under dynamic steering loads and causing the toe-in to change, albeit by a very small amount. Conversely, the T-Bird inner rods have a threaded steel socket formed around the ball end to a very nice tolerance. BTW, the nylon button was also split in three places. Nice piece eh? Any advice out there?
Cheers,
Rick
Cheers,
Rick
- ncwitte
Rick, I can't help you on your suspension question but the car looks awesome!
Norm Witte
Lansing, Michigan
Lansing, Michigan
- Rick Calcitrant
This next series of photos shows the "backbone" chassis integrated into the unibody. Some additional links from the chassis to the body remain to be done but I'm holding off due to a lack of commitment on my part to the engine selection, commensurate exhaust routing and some issues surrounding the fuel tank and radiator placement up front.
Now to mount the suspension and steering.
- Vaircooled
I feel like I am in advanced mechanics class. Absolutely amazed.
Shane
1960 700 Sedan
1960 700 Sedan
- ncwitte
This is so cool. I love the high quality work here.
If I understand correctly, the Kelmark conversions flipped the stock Saginaw transaxle. One issue was lubrication, since it was designed to use gravity to return oil. My recollection was that a separate oil pump was necessary to fix this. Is that going to be true of the this transaxle as well?
Norm Witte
Lansing, Michigan
Lansing, Michigan
the quality of what you are doing is incredible, i'm not sure GM could have done it better
Nice, VERY NICE!
Charles Troutman Sr.
Charles Troutman Jr.
Glendale, AZ
66 Vair-8
68 Vair-8
65 Convertible
V-8 Registry Member
Glendale, AZ
66 Vair-8
68 Vair-8
65 Convertible
V-8 Registry Member
Sweet!
- TikiRalf
Holy WOW !!! thats way cool , good job dammmmm gonna follow this project :-) keep on going
- Rick Calcitrant
Thank you all for the supportive comments.
Norm, to answer your question about trans lube, I've done a considerable amount of research on that with respect to the 930 trans. By all accounts, those being mostly mid-engined kit car conversions, the "flipping" procedure is acceptable with no discernible harm to the transaxle. It really depends on who you ask. I queried "Renegade Hybrids" (914/SBC guys) some time ago and they "suggested" that the ring gear option was preferable but then they perform the machine work so there's a bit of a conflict of interest. They're applications also benefit from leaving the 930 box in its right-side up orientation due to motor mount issues, shift linkage, and half shaft inclination. If anybody out there has anything to add I'd be grateful to hear from you. Thanks for your interest.
BTW, I'm currently prepping the suspension for installation and since all your positive comments have me amped up, I'll try to do better about taking more detailed pictures.
