There are several options in the conversion:
- Use an externally regulated 10DN Delco alternator, as seen on late model 1965-69 Corvairs.
- Use an internally regulated 10SI or 12SI Delco alternator off a slightly later GM product.
- A true one wire setup. Here a special self exciting regulator is installed in a 10SI style alternator. Control of the dash idiot light is lost if this is used.
The explanation shown below, along with its website link, seems to be one of the best explanations I've seen seen that describes some of the Delco alternator options available that could be fitted to a Corvair. (Keep in-mind the reverse rotation of the Corvair engine, which does not affect the alternator charging system but must be considered when fitting a cooling fan and pulley to the alternator — since the cooling fans are designed to rotate either clockwise or counter-clockwise. Proper air circulation is important for cooling an alternator).
A standard Corvair alternator output capacity:- Alternator P/N: 1100639 — 35 Amps
- Alternator P/N: 1100698 — 45 Amps
An alternator with an internal electronic voltage regulator makes good use of the increased reliability of a solid-state voltage regulator to replace the 1960s vintage external electro-mechanical voltage regulator. However, a switch to a single-wire alternator instead of a 3-wire alternator cannot be justified, and is not desirable in my opinion. The reasons are clearly described below...
Alternator Conversion
Selecting a Delco SI-Series Alternator
[url]http://bob_skelly.home.comcast.net/~bob_skelly/alternator_conversion/wiring_alternator1.html[/url]
To replace an EM generator with an alternator, the oil filter and generator mount adaptor must be replaced with the oil filter and alternator mount adaptor found on 1965-1969 Corvair engines. These used adaptors can usually be obtained from sources on eBay or from sources like the Corvair Ranch in Gettysburg, Pennsylvania...
http://www.corvairranch.com/
Suitable alternators can be sourced from normal Corvair suppliers, auto parts suppliers, eBay, local automotive junk yards, etc.
This link provides some additional information on the CCW rotation alternator fan and proper cooling for a high-capacity alternator mounted on a Corvair engine...
http://corvaircenter.com/phorum/read.ph ... 130,612166
More information on fitting newer-design Delco alternators to Corvairs...
http://www.unm.edu/~geoffj/Vair/Alternator.html
